Notices
2ndgen Ram Air Hat: Magnum Engines
Old Aug 28, 2010 | 12:35 PM
CPTAFW163's Avatar
CPTAFW163
Default 2ndgen Ram Air Hat: Magnum Engines
I fabbed a Ram Air box from two stock Dakota airboxes. I painted it black wrinkle, along with the mounting hardware.
If you want to do this with your Magnum power car/truck:
Here is everything you get:
Ram Air Hat
Bent threaded bar for offset throttle bodies
Scoop mounting brackets and self tapping stainless steel screws
Ram Air Scoops
K&N 9.75x3 air filter
Vinyl tubing for the scoops to create a tight seal
Closeup of box:
Hardware:
The little black circle thing is to ensure that the top of the airhat is airtight. You put that on after you get the lid on but before you put the wing nut on and tighten.
This airbox can give .5-1.0 lbs of boost at 75 MPH depending on your engine (Higher displacement, the lower the boost will be)
Cost, $100 plus shipping.
--Dan
Old Aug 29, 2010 | 04:43 PM
CappinHoff's Avatar
CappinHoff
Wow that is awesome. It looks like a factory piece.
Old Aug 31, 2010 | 07:20 AM
bigslick050's Avatar
bigslick050
So is it still available? My brother might be interested...
Why are you selling it anyways? You just built it...Or what needs to be fixed to make 100% perfect?
Old Sep 20, 2010 | 07:55 PM
CPTAFW163's Avatar
CPTAFW163
oh, I am selling it because the tubes are a really tight squeeze and i don't have the patience to set aside a whole day for fitment.
However, I am going to hold off on selling it because I think I can use it if I get about 3 inches of PVC pipe to use as an extension so i have more room to work with. Or even get some aftermarket tubing.
I just thought this was a "slap on" type mod, but it takes some doing to get the fitment perfect. Took so long to fab up, that I just wanted it on there.
--Dan
Old Sep 20, 2010 | 10:09 PM
Salex007's Avatar
Salex007
did you see these? Another ram owner did this on *********
http://www.schmidtmotorworks.com/pro...r_cleaner.html
Old Sep 21, 2010 | 12:17 AM
CPTAFW163's Avatar
CPTAFW163
yeah, and I saw a chrome one on ebay for 70 bucks new (WITH a cloth filter). But this one does not include the plumbing or filter, so I decided to go to a junkyard and get some stock parts. It was 60 bucks for 2 stock air hats WITH the plumbing (scoops). And it is not plastic. Plus, that 1.2 inch drop base would make you need to get a spacer.
It is a lot more money to do that setup. Might as well get the spectre system from Jegs for 99 bucks (does not include filter though)
Old Feb 27, 2011 | 01:35 PM
97ramnj's Avatar
97ramnj
hey i was just curious if you still have this, i want to get a new filter setup and i was interested awhile back, but id def like to grab it if you got it
Old Feb 28, 2011 | 08:27 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Might wanna shoot him a PM
