Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Speaker Install Help
Old Mar 31, 2007 | 09:31 PM
en1gma01's Avatar
en1gma01
Default Speaker Install Help
I have a 200 durango with 6 speakers and i need help installing Infinity 60.7cs speaker in the front doors.
http://www.upload2.com/?cmd=_viewer&...pg&s=a509a
how do i install the wires to this. I thought it was easy but i only have 2 wires inside the door. 1 from the tweeter and 1 going to the speaker. thanks in advance.
And do i even need the crossover?
Old Mar 31, 2007 | 11:37 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: Speaker Install Help
What do you mean you only have 2 wires? There should be 2 SETS of wires. a + and a - for each speaker. And yes you need the crossover, unless you wanna blow that tweeter real quick
Old Mar 31, 2007 | 11:57 PM
en1gma01's Avatar
en1gma01
Thats what I ment, but there are 3 inputs to put things on the crossover. I know the one on the right is the tweeter. How do i connect the other 2?
Old Apr 1, 2007 | 12:36 AM
en1gma01's Avatar
en1gma01
Ok I think I got this.
The "in" input is the original woofer wires
The "wf" input goes to the new woofer
The "tw" goes to the tweeter
Is that right.
Also what guage of speaker wire should I get?
Old Apr 1, 2007 | 09:59 AM
BeachCrawler's Avatar
BeachCrawler
Yes, that is it.
Old Apr 1, 2007 | 01:47 PM
bad venge's Avatar
bad venge
Section Moderator
Do you have an external amp ??? No amp any normal speaker wire is OK, higher powered amp need larger wire
but yes input the wires from the head unit to the in then the outputs split up the way you state
Old Apr 1, 2007 | 03:05 PM
en1gma01's Avatar
en1gma01
Thanks for the help, i'll finish the install today.
Old Apr 2, 2007 | 12:34 AM
en1gma01's Avatar
en1gma01
Got them installed and they sound fantastic. Again thanks for the help everyone that replied. Now I need to buy some infinity 62.7i to replace the rears.
