Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Capacitor Installed, No Digi Display
Old Apr 19, 2007 | 11:28 PM
l33tn3wb3r's Avatar
l33tn3wb3r
Default Capacitor Installed, No Digi Display
So ya, I got it installed at Best Buy. I bought the 1.5 Cap. through an online site for 30 bucks. After I got it installed, [professionally I might add] I noticed my Digital Display on it was not working. Could this be due to a lack of some wires not being upgraded to 4 AWG? my power and ground for it are, but my power wire and another ground under the hood are not. Any suggestions? I'm just hoping it's not a faulty capacitor; I'm very impatient when ordering/receiving and or sending back for replacement -.-
Old Apr 20, 2007 | 12:05 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Capacitor Installed, No Digi Display
Most with display need a remote wire hooked to it to turn the display on and off ...Consult your owners manual to confirm this ...
Old Apr 20, 2007 | 03:12 AM
habeba86's Avatar
habeba86
ORIGINAL: bad venge
x2.......a few work on voltage change, but not many.
Old Apr 20, 2007 | 12:42 PM
rtkota5point9's Avatar
rtkota5point9
Most smaller caps up to 2 faradusually work on voltage change, larger onesusually work on a remote wire. But it sounds like yours might have the remote wire setup. If not, then it is a faulty cap. It would have nothing to do with the size of your power or ground. They may effect the actual voltage reading on thegauge if it's a bad ground, but it won't make it not come on.
Old Apr 20, 2007 | 04:08 PM
big t cbb's Avatar
big t cbb
i had the same problem once... prolly like they said remote wire or my problem was the inline fuse wasnt tight...
Old Apr 20, 2007 | 05:42 PM
l33tn3wb3r's Avatar
l33tn3wb3r
The first thing I thought was remote as well. Alright I'm looking at the manual as I am typing this. I'm looking at a page that has TWO diagrams. The top shows a remote coming off the top of the cap., and the bottom one without a remote hookup. At the top of MY capacitor, I have my Positive and Negative, and I also have a third smaller screw, so it forms a triangle on top of my cap. That may possibly be my remote? If so, ya it's not hooked up anywhere, and why would there just be a random tiny screw on top right? Well to the right of that diagram it shows model numbers....mine is CA155XB. The list next to that diagram only shows 100XB and 150XB haha, but I suppose if you just rounded down >.<.
Old Apr 20, 2007 | 08:03 PM
rtkota5point9
If you have an extra smaller terminal on the cap then I would wager that's your remote wire. Hook that tot he same remote wire as the amp uses and it should pop on. The cap will still work without that hooked up, you just won't have the display.
Old Apr 23, 2007 | 03:23 AM
l33tn3wb3r's Avatar
l33tn3wb3r
Ya it worked. Sorry I didn't respond to this faster, i've been working alot. The "professional" I had hook my cap up must not be all that professional. It took me like 2 minutes just to hook it all up, and she works like a charm. Thanks for all your help guys.
Old Apr 23, 2007 | 06:54 AM
habeba86's Avatar
habeba86
Who put it in?
Old Apr 23, 2007 | 01:41 PM
bad venge's Avatar
bad venge
Section Moderator
In his other thread it was going to Best Buys or Circuit City ... for a $15 install
