Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Amp grounding help please
Old Apr 23, 2007 | 01:52 PM
McGillicutty's Avatar
McGillicutty
Default Amp grounding help please
Just finished installing my amps and ran the ground wire to the seat frame, bolting the wire connector to the stud on the seat frame where the fold out floor mounted. I sanded the paint off and figured the four seat bolts would have to be a sufficient ground. Fat chance. I've got noise up the gazoo. Where are you guys grounding to? Thanks.
Old Apr 23, 2007 | 02:01 PM
habeba86's Avatar
habeba86
Default RE: Amp grounding help please
Thats where mine is grounded. Check your headunit ground.
Old Apr 23, 2007 | 03:09 PM
McGillicutty
My head unit is grounded via the factory wiring harness using an aftermarket harness adapter. I can pull the head unit out and make sure the wire connector hasn't come loose, but short of that I'm not sure how I'd confirm if it's a solid ground or not. I've got a fairly loud hum with the truck off and volume at zero. Starting the engine results in the engine noise. My power cable is routed on the driver's side and RCA cables on the passenger side. It's puzzling.
Old Apr 23, 2007 | 03:22 PM
bad venge's Avatar
bad venge
Section Moderator
Take the ground wire loose from the amp , then use a voltmeter on Ohms to check the resistance touch the leads together and get a reading (normally like .01 Ohm) Then touch one to the seatbolt and the other to the wire , subtract the two readings and thats the resistance ... The lower the better
You could have a ground loop issue and need an Isolator too
Old Apr 23, 2007 | 09:31 PM
whiteram00's Avatar
whiteram00
i alwasy runned my power wire away from my rca's,may be gettin some nosie that way,but like alot of ppl i grounded my amp to the seat bolts,ive alway did that an never had a prob,hope you figure it out
Old Apr 24, 2007 | 04:20 AM
habeba86's Avatar
habeba86
If its with the engine on it is more than likely alternator whine.
Old Apr 27, 2007 | 04:17 AM
spaz_22's Avatar
spaz_22
also check your spark plug wires. this can cause a whine through the engine, but the alternater is a large possibility of the sound, if you rev your motor and the sound gets louder it's not your radio or ground.
Old Apr 27, 2007 | 06:06 AM
Altair's Avatar
Altair
Dak attack!
Factory ground isn't always a good path for grounding your headunit. Try cutting the ground wire going to the factory harness and ground it to the chassis under the dash somewhere.
