Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Kicker 750.1
Old Apr 27, 2007 | 01:09 AM
cr80renob's Avatar
cr80renob
Default Kicker 750.1
I am running two 750.1 Kicker amps (soon to be 3!) and I wanted to know if it is possible to wire the two bass control ***** together?
Old Apr 28, 2007 | 10:07 PM
djeazie's Avatar
djeazie
Default RE: Kicker 750.1
Ya know those look like telephone type plugs, maybe you could find a splitter that you could plug your bass **** in then with a splitter run 3 separate wires off the adapter or splitter to your amps. You might just luck out! By the way I have the same amp, this thing is an animal. My birthsheet showed 930 watts! What a deal pay for 750 and get 930, gotta love Kicker!
Old May 4, 2007 | 10:58 PM
cr80renob's Avatar
cr80renob
I LOVE KICKER! Haha... Thanks for the input, I get the amps Tuesday, and that is when I will see if I can have one **** control the two amps! I'll let you know how the system sounds when it is all done!
PS- I will be running two zx750.1 amps, and they will power two cvx 12" subs!
Old May 5, 2007 | 11:58 AM
rtkota5point9's Avatar
rtkota5point9
Should sound badass! The CVX's are really nice. I had a 10" a little while back. And I'll have another soon.
Old May 5, 2007 | 12:03 PM
rtkota5point9
BTW, what are you running for cable and batteries << Plural
Old May 5, 2007 | 10:18 PM
cr80renob's Avatar
cr80renob
ORIGINAL: rtkota5point9
I'm gonna have two zx750.1 amps and two CVX- 12" subs.....
I haven't really thought about an extra battery! I guess I was too excited just to get the other stuff!
[sm=jawdrop.gif]
What do you recommend for an extra battery?!
Thanks,
Shane
Old May 5, 2007 | 10:21 PM
cr80renob's Avatar
cr80renob
Another question.....
This is gonna sound dumb, but I have to ask it any way! How will I keep the extra battery charged? Will I have to hook it up to a charger every once in a while?!
I know, I know, it's a stupid question but I am just wondering......
[sm=alcoholic.gif]
Old May 6, 2007 | 01:29 AM
rtkota5point9
No, the second battery will hook up to your existing charging system so it will get charged just like the factory battery does. You'll wire it much like your amplifier. You want a battery that matches what you have up front. If you're going to be putting the extra battery in the passenger compartment,you should really look into a dry cell battery, like an Optima red or yellow top. But if you do that, you should really change the one under the hood to the same thing.
The 750.1 has a regulated power supply. 2 Batteries are HIGHLY recommended! Even with only one 750! On the kicker amps, if the voltage gets below a certain spot (10.5V I believe) It can damage the power supply and kill the amp. I havn't seen any 750's come back yet for that reason, but seen LOTS of larger ones like 1200's and 1500's come back because the user either didnt run extra batteries, or they played the system with the vehicle not running. The larger the amp, the more suseptable they are. They are supposed to have low voltage protection, but it doesnt seem to work. lol
What size power and ground are you using?
EDIT: And why don't you just run 1 ZX1500.1 instead of the 2 750's? It would make tuning easier and take up less space, cost less,no dist blocks, less wiring, ect, ect
And what configuration did you get for the CVX's The dual 4ohm, or dual 2ohm voicecoils?
Old May 7, 2007 | 02:43 AM
cr80renob's Avatar
cr80renob
Not sure what size power and ground wire I am using. I was going to wait and see what an installer would suggest. What do you recommend?
I went for the dual 4ohm CVX's.....
Old May 7, 2007 | 02:54 AM
cr80renob's Avatar
cr80renob
I was told that THIS POWER KIT would work... Is that true? If not, which one would?
Thanks a lot rtkota5point9 for all your input! You are helping out immensely!!!
Shane
