Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
wiring
Old Jun 6, 2007 | 08:19 PM
busta1121's Avatar
busta1121
Default wiring
im trying to hook up a line out converter need wire diagram. 07 dodge ram 1500 with 7 speaker sirius 6 disk system. please help..
Old Jun 6, 2007 | 10:27 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: wiring
This is all I have on the 07 ... Dunno if this is enough to get your line convertorhooked up
Battery GRAY/LIGHT GREEN (+) RADIO HARNESS
Accesory THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER.
THE ACCESSROY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/LIGHT GREEN (-) RADIO HARNESS
LF Speaker (+) GRAY/VIOLET
LF Speaker (-) GRAY/YELLOW
RF Speaker (+) DARK GREEN/VIOLET
RF Speaker (-) DARK GREEN/YELLOW
LR Speaker (+) DARK GREEN/TAN
LR Speaker (-) DARK GREEN/GRAY
RR Speaker (+) DARK GREEN/BROWN
RR Speaker (-) YELLOW/GRAY
Steering Cntrls OPTIONAL
Speed Cntrl OPTIONAL
Radio Security YES
Old Jun 6, 2007 | 10:38 PM
busta1121's Avatar
busta1121
Default RE: wiring
also i wondered if i have to hook it up from the radio or from the stock amp behind glovebox? i hope just from the radio
Old Jun 6, 2007 | 10:55 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: wiring
Either will work or even can do it off the rear speakers(assuming you are running another sub)
Old Jun 6, 2007 | 11:24 PM
busta1121's Avatar
busta1121
Default RE: wiring
there is two harnesses going into the radio one is small and the other is large. I unplugged the small harness and it seems to be only for the sirius.; Now on the large harness there is only 10 wires and they are as follows..
black
black/green
gray/blue x
gray/orange x
green/orange x
green/blue x
white
white/orange
dark gray/red x
dark gray/maroon x
i do know that i got sound out of they ones with an X. But im not sure which speakers they are for or + and -
Old Jun 7, 2007 | 02:08 AM
rtkota5point9's Avatar
rtkota5point9
Default RE: wiring
Those colors dont make sense, are you sure the "orange" stripes, werent yellow?
Old Jun 7, 2007 | 03:39 AM
busta1121's Avatar
busta1121
Default RE: wiring
this is what i found...
http://www.the12volt.com/installbay/....asp~TID~86102
i hooked up the line converter but for some reason when the volume is turned way down alll i can hear is the subs and not anything else. When i turn up the volume the subs don't put out much bass.
Old Jun 7, 2007 | 03:57 AM
habeba86's Avatar
habeba86
Default RE: wiring
Did you get the wires behind the radio or after the amp?
Old Jun 7, 2007 | 04:09 AM
busta1121's Avatar
busta1121
Default RE: wiring
from the radio
Old Jun 7, 2007 | 04:11 AM
busta1121's Avatar
busta1121
Default RE: wiring
also i put the amp turn on lead to the fuse panel for the radio but i noticed the amp stays on all the time. Is there a better place in the fuse panel to put it?
