Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
reverse facing subs??
Old Aug 14, 2007 | 01:27 AM
neonracer1010's Avatar
neonracer1010
Default reverse facing subs??
facing the subs into the inside of the box, is this a plus or a minus
Old Aug 14, 2007 | 03:09 AM
habeba86's Avatar
habeba86
Default RE: reverse facing subs??
It doesnt matter....inverting does nothing, but get you a little more room inside the box.
Old Aug 14, 2007 | 09:59 AM
Captain Pioneer's Avatar
Captain Pioneer
^^^ Makes no difference other than asthetic appeal, increased Enclosure room... which is only like .3 to .7cuft at the most, and a really nice chance of having somethign get caught between the cone and the spider Other than that no difference... I believe you have to run in polar opposites though when u invert... I might be wrong about that though???
Old Aug 14, 2007 | 11:46 AM
habeba86's Avatar
habeba86
ORIGINAL: Captain Pioneer
^^^ Makes no difference other than asthetic appeal, increased Enclosure room... which is only like .3 to .7cuft at the most.
If you have a sub that takes up .7cf you have one GIANT sub lol
Old Aug 14, 2007 | 12:21 PM
rtkota5point9's Avatar
rtkota5point9
^ x2 lol And yes, if the subs are inverted, the polarity should also be reversed. Some headunits have a setting built into them. Otherwise just swap the speaker leads around.
Old Aug 14, 2007 | 02:31 PM
Captain Pioneer
ORIGINAL: habeba86
I believe my buddy who just started making his subs... displace something around that... HUGE HONKIN SUBS lol
Old Aug 14, 2007 | 04:35 PM
the727kid's Avatar
the727kid
Not even close... My TIs were huge subs and had a displacement of .17....a shock sig, which is the biggest motor I have ever seen would probally take up close to .3
Old Aug 15, 2007 | 08:14 AM
rtkota5point9
Yeah .7 is outrageous, maybe if you had a HUGE sub, and wrapped it in plastic so there was no wasted airspace between the motor structures (Spider, cone, Pole/Vent) then the entire assembly might take up close to that. But a sub has a lot of empty airspace in it. Even if it looks huge, there isn't a whole lot of mass there.
Old Aug 15, 2007 | 12:52 PM
Captain Pioneer
You are correct i just asked him what the displacement was and he said on the 18" that it was .48 so i was completely off. I thought it was bigger though... But still its a rediculous sub.. 6kw for 10mins strait is pretty durn nuts to me... Im not crazy SPL like he is but he def has a couple screws loose
Old Aug 28, 2007 | 11:52 AM
bigmac18's Avatar
bigmac18
So when you reverse the polarity on the subs, do you just switch the + and - on the speaker terminal on the amp, or do you have to switch the connections on the sub?
I have 2 10" Kicker L5's. They have dual voice coils, and I have a seperate amp going to each one.
should I just switch the + and - at the amp?
---> this is how I have each one wired.
