150 db?
Out of curiosity, what is the minimum cone size/power to hit 150 db in a single cab? Not trying to be cheap, but I would like a general idea before I start planning. Also, if you were to build your dream system in an 05 Ram regular cab, what would it be? Open to almost anything that doesn't require cutting the truck up, or removing the stock power bucket seats.
So you want something that will cause permanent hearing loss instantly, something louder than a jet engine and has no practical purpose other than pissing off the neighbors and draining your wallet?
OK - Find the most efficient speaker rated at 1 watt, then double the wattage for every 3 dB. If you can find a very efficient speaker -say onerated at 100 dB at 1 watt, which is pretty good - you'll need more than 65,000 watts to achieve 150 dB. Good luck fitting that in a regular cab pickup! That's why you see SUV's and vans at Sound-Off's. Besides they only give credit up to 140 dB in the SPL judging anyway. That requires only 8,000 watts.
My suggestion is to pop in the ear buds and crank 'em all the way up. Get a massaging chair and you'll achieve the same effect without pissing off the neighborhood....and it's a hellofa lot cheaper!
ORIGINAL: crcarch
7secR/C, you might want to visit some audio shops in your area and go onto the termpro website that is the website for car audio competitors. You could have the system you want, but in order to do so then you are going to have to sacrafice and possibly do some cutting on the truck itself.
You may beright about them giving credit for over 140 dB. Looking back at the article I got my info. from, I realize that it was about 10 years old. Sorry if I contributed to anymisinformation. I still think its nuts to try to do something that'll cause permanent damage. Of course I've been known to do ignore common sense myself from time to time.....so to each his own! [sm=smiley20.gif]
ORIGINAL: crcarch
Trending Topics
2 JL audio 12w7's pushed by2 JL1000/1 amps produced 148.5 in my honda civic hatchback. with a little work you might could get close with that setup in your truck. use a 2nd battery tho and a cap wouldnt hurt either. use high-end cables and wires to squeeze everyhing you can out of em
Its possible to hit 150 db in our Ram trucks, depending on the space though. I have 2 12 inch subwoofers in a1500 Extended Caband i'm putting out 140+ db (no local termlab, so i can't show you it) but i have a db reader and thats what it says with windows and doors closed and just the db reader measuring the db.
I'd recommend like two Rockford Fosgate 15 inch subwoofers and if you got the money buy 2 18 inch Rockford Fosgate subwolfers, with 2 3000 watt amps or 4 1500 watt amps (2 per sub) and 4 batteries. (expensive stuff [
Theres a guy with a Chevy Tahoe that has 4 18 inch Rockford Fosgate subs with 8 1500 watt amps 2 per sub that puts out 20,000+ watts and has a 157 DB on a termlab.
Crazzzyyy.
![Embarrassment](https://dodgeforum.com/forum/images/smilies/redface.gif)
Crazzzyyy.
