Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
04 Ram SRT-10 Stereo Install help please !
Old Nov 26, 2007 | 12:09 AM
Asab's Avatar
Asab
Default 04 Ram SRT-10 Stereo Install help please !
I went to install a new Pioneer N4 Stereo in my 04Ram SRT 10however I can not make the Amp come on...I have power and everything else but the amp will not turn on ? What do I need to get the dam amp to turn on I want to use my factory amp it sounds fine to me and I want to use it...Also where is the VSS wire for the navagation part ....I know the amp thing has something to do with the Streo going off when I open the door...Do I need a special Interface and if I do where can I get it ...Any help you guys can give I thank you ....Asab..........
Old Nov 26, 2007 | 12:49 AM
Dutch's Avatar
Dutch
Default RE: 04 Ram SRT-10 Stereo Install help please !
Do you have a harness adapter that looks like this ?
http://www.bestkits.com/ViewImage.as...=i/BHA1818.jpg
If you have the Infinity system it says you must relocate the radio and provide power to it.
http://www.bestkits.com/SearchResult...002%20-%202005
As far as the amp not turning on you need to hook up the remote wire from your aftermarket HU.
As for the VSS wire your gonna need a wiring diagram for your vehicle.
Good Luck,
Dutch
Old Nov 26, 2007 | 06:43 PM
Asab's Avatar
Asab
I found out today they do not make a interface from PAC or the other guys (forgot there name)They said 2004 was the only year they did not have an interface for so I amamp and speaker bound...Just thought I wouldthrow it out to everyone here...If you have a 2004SRT-10 andwant to use your amp your out of luck.....Asab.........
