Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Removing some of the interior panels...
Old Dec 26, 2007 | 08:26 PM
mn12sc35gh's Avatar
mn12sc35gh
Default Removing some of the interior panels...
I'm looking to run an amp from the stock headunit, so I'm going to tap into one of the rear speaker outputs and run a hi-level input to the amp. Also need to run an remote turn on, so I'm looking at the cigarette lighter for that. I need to know how to get these panels off before I go break something....
It's a regular cab 07 with a manual trans (floor cupholder/consle thing...)
Rear side panels (for the speakers)
Center dash panel (for the lighter)
The bottom door sill cover (to hopefully hide my power wire)
The floor mounted cupholder/shifer cover (to hide my remote wire)
Thanks in advance!
Old Jan 9, 2008 | 05:30 PM
Duranged408's Avatar
Duranged408
Default RE: Removing some of the interior panels...
My first suggestion (not knowing the interior) is get a book, will help you out lots and i recomend it to anyone for anything they drive. I'd say pass on connecting the remote to the cig lighter and just pickup a tap in fuse kit to put in your fuse block, run it in the sil along with the other wires.(use a meter to find a ig/aux hot space)- this aswell easier than removing your center/dash- Most dodges sills are held in with tabs so they just pull right out, and the kick panels screws/bolts. Doors im unsure, alotta vehicles are different so im not going to suggest something that breaks a tab or even worse a panel.
Old Jan 28, 2008 | 03:54 PM
habeba86's Avatar
habeba86
http://documents.victorytechnologies...ct/99-6510.pdf
Old Jan 28, 2008 | 03:57 PM
StevenMoffettKY's Avatar
StevenMoffettKY
Do you have a PDF handy for the 2005 RAM interior? Doors, dash, etc? I saw an old post saying you were going to try to dig one up, but never saw it posted. Thanks!
