Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Wiring Diagram & Pinout For 07' Ram Radio
Old Jul 22, 2019 | 06:45 AM
hassan ali's Avatar
hassan ali
Smile techsupport
Identifying car stereo wires might seem intimidating, but in truth, figuring out the purpose of each wire in a factory car stereo wiring harness is actually pretty easy. You can either track down a wiring diagram for that specific make, model, and year, or you can grab an inexpensive multimeter, which is a wiring project, and an AA battery, and figure it out on your own.
Tv Reapir
Old Dec 7, 2020 | 03:31 PM
keyboardr4him's Avatar
keyboardr4him
I am changing my 2007 Dodge Ram 1500 stock radio for a BOSS aftermarket. I got the speaker wires spliced, but I also have 2 constant power Gray/Red wires and 2 Green/Black ground wires. I don't have the Pink/White Acc. wire people keep mentioning. I can't get the radio to come on at all. What am I missing?
Old Apr 18, 2021 | 08:52 PM
JustinLyndsey Kirkman's Avatar
Originally Posted by jseevers4
Hi Sirhannek,
I am doing the complete opposite as you. I am changing out my 07 factory stereo with a pioneer component. I did notice in the pictures you posted that you do not have the second connector on the radio you are installing. This connector has 3 wires for the 12 V main, the ignition switched and the dimmer. I will reply tomorrow with which holes these are located in on the second plug. NOTE: you may have problems finding this as all of the radio shops that I have been too do not have the female pigtail for me to connect from my aftermarket to the factory harness. You may have to go to a pick&pull or get directly from the dealer. Your radio will not work without this connector.
The CWH-638 connector will only be used for the speakers not the power to the radio.
Regards,
Jeff
This ever get solved?
Old Mar 19, 2023 | 08:19 PM
Bludryn's Avatar
Bludryn
Did you ever get an answer to this question? Im dealing with the same thing on my 08... two constant hots and no ignition wire
Old May 5, 2023 | 11:44 AM
scarr83's Avatar
scarr83
Question
Hey, did you get this fixed? We had this same problem last night. What my husband did was he attached the acc/ignition wire on the radio harness to the left side cigarette lighter, which is the lighter that does not stay on when you turn the truck off. Hope this helps if you haven't fixed this yet!
