Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Quick speaker question
Old Jan 9, 2008 | 10:24 PM
cr80renob's Avatar
cr80renob
Default Quick speaker question
I want to install a pair of kickers in the front doors and have one quick question...
Do I have to buy an adapter to hook into the existing stock wire plastic piece, or can I just cut that plastic piece off and hook the wires directly to the speakers?
Thanks,
Shane
Old Jan 9, 2008 | 10:32 PM
Duranged408's Avatar
Duranged408
Default RE: Quick speaker question
I've never looked for adapters, i've always cut them off and soldered. ** Almost forgot, heat shrinked afterwards
Old Jan 9, 2008 | 10:42 PM
cr80renob's Avatar
cr80renob
Ok cool, What color is positive and what color is negative?
Thanks,
Shane
Old Jan 9, 2008 | 11:29 PM
Duranged408
All i could find was a premium system diagram, im not sure that has the same color coding. Maybe someone will chime in soon
left front door
dkgrn/ltblu negative
dkgrn/yel positive
right front door
gry/lt blu negative
gry/lt grn positive
Old Jan 10, 2008 | 04:27 PM
Redram05baby's Avatar
Redram05baby
If Your Going To Install Nice Speakers... it Really Needs To Be Amped.. And If Its AMPED. You Do NOT Want To Use Your Old Speaker Wire.
I Would Reccomend Running New Speaker Wire..
Its All Clean In A Sealed Loom, And Grommeted.
I Installed Boston Acoustic Componets. And It Was A LOT Cleaner With New Wire.
Hope That Helps.
A. Jones
Old Jan 28, 2008 | 03:57 PM
habeba86's Avatar
habeba86
They do make adaptors...you dont have to have them. I wouldnt worry about the speaker wire unless you plan on running say 70rms or more to them.
