Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
My Double Din conversion.. pics
Old Mar 29, 2010 | 08:33 PM
04_ramslt's Avatar
04_ramslt
that looks great so far cant wait to see the finished pics. Im hoping to do something similar soon
Old Mar 30, 2010 | 07:24 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
you definitely need to put the GPS ant under the dash cap. Dont worry it will work fine.
Old Mar 30, 2010 | 08:15 AM
tomalaina's Avatar
tomalaina
Originally Posted by ramhunter9
wonder if this can be done on the new style dash??
Yes - here is my 2007 QC 5.7 4x4 with a Double Din Kenwood. I even did a double power outlet as i dont smoke and didnt need a lighter.
Old Mar 30, 2010 | 10:36 AM
Matt99's Avatar
Matt99
yea RH, you can cut yours to make it fit, but will have those holes from the volume/channel buttons. I messed up and got a flip out 1 1/2 din, wish I woulda gotten the double din. Just installed one in my buddies dodge. Just dremeled the center bar out of the bezel and I cut some abs plastic for those holes
Looks good OP, how much was that HU
Old Mar 31, 2010 | 02:02 AM
huseman808's Avatar
huseman808
Here we go... Got it all done today, took about 8 hours total to do the dash bezel start to finish.
First I cut the opening to size and Gorilla glued plastic pieces to the sides.
I taped off the area to be bondo-ed then bondo-ed it. I wanted to keep the texture of the bezel from that crease down, and have just from there up be smooth.
First layer sanded down with 80grit and then I checked for placement.
2 more layers of bondo and sanding were done to get it perfect and here it is after the final sanding.
Wiped it all down with a lacquer thinner and masked it all off.
Primer.
Painted flat black and installed.
I am happy with the way it turned out. The only thing left im gonna do is sand it down with a fine sandpaper like a 900 or 1000 and give it a final coat. I'm really proud of this whole install. What'yall think?
Old Mar 31, 2010 | 02:22 AM
Matt99's Avatar
Matt99
I think you did a damn good job. Sticky for sure!
Do you only have bondo filling in the sides or is it some abs also?
Old Mar 31, 2010 | 02:28 AM
huseman808's Avatar
huseman808
Yes, on the sides I glued in some ABS and then bondo-ed over them.
Old Mar 31, 2010 | 02:32 AM
Matt99's Avatar
Matt99
okay I see it now, the pic wasnt up a minute ago. Anyway, looks great. I wish I woulda got the double din for sure, so much cleaner
Old Mar 31, 2010 | 02:33 AM
rocket23's Avatar
rocket23
nice job glad you have the old style dash the o6's have that dumb squared out area on the pass side thats well I have no idea what it's for I might want too bondo that closed. Does anybody no what i mean
Old Mar 31, 2010 | 02:40 AM
Matt99's Avatar
Matt99
are you talking about the circles where the volume/tune buttons are or the little cubby hole where the 4x4 switch is on the L side and nothing on the R
