Underseat Subwoofer Question
Well I have two Kicker 2ohm DVCs in my Foxbox. Each sub is wired in series to get 4ohm per sub and then both subs are wired in parallel to get me a 2ohm load on my mono amp (1600 watts total or 800 per sub) and it sounds great. I think the highest dB I hit on my meter was 129 which isnt bad. But the difference the Foxbox made over the Probox was incredible.
Got ya, well from what this guys telling me is this 1 10" probox sub/enclosuer @ 400 RMS at a 2ohm load after I give it a good tune should hit around the same db your getting.
But from what he told me the Probox with a different sub other the the Probox sub won't be as good as with the Probox sub. Its all formulated where the box are the exact specs for the sub.
Guess ill find out soon when I do the install. I'll be sure to post a vid.
