Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
The System I Have...
Old Jul 9, 2006 | 02:09 AM
  #131
DemEyz's Avatar
DemEyz
Default RE: The System I Have...
2 12' Orion P12's that push 1000 watts apiece in an enclosed box
1 2 channel 2400 Orion Amp to push my monster subs
2 6.5 Pioneer Premier Door Speakers (260 watts i believe)
2 Pioneer Premier 6x9'sq
Pioneer DEH-P6800MP Head Unit
All that in my 96 Neon........and i am still not finished.
Old Jul 18, 2006 | 12:53 AM
  #132
DODGERAM808's Avatar
DODGERAM808
lets see, i had 3 12 jl's in my ram with a 1000w audiobahn. i sold the system and the truck. i now have 2 15w3 jl's and a 1600w audiobahn. 6.5 mb quarts in the doors 4 sets of tweeters + the ones on my coaxials and a 4 channel running the mids. pioneer premier deck and clarion eq. thanks.
Old Jul 18, 2006 | 04:29 PM
  #133
HighDuke1911's Avatar
HighDuke1911
My mom has 2 JL w6's in her Honda CRV. I put those subs in there. I have a 500/1 JL amp running to them. She also has a Pinoeer AVIC-N2. I'm getting 2 Infinity Kappa's put in my truck, I'm not sure about what amp I'm gonna get hooked up there. I'm gonna also get a flip-out deck similar to my mom's.
Old Jul 29, 2006 | 03:21 PM
  #134
god_complx's Avatar
god_complx
I have 2 Lanzar 15's in a bandpass box 2 Phoenix gold Amps which gives me about 1500 watts, a 1 farad capaciltor, 1200 crank amp battery, 4 guage wire to the amps 8 guage to the subs 12 guage to the 6 speakers. I have registered 153 db, which isnt much nowadays, but remember a jet at takeoff is only 135!!!!! Love the sound love the speed. Now in my Magnum I havent upgraded yet, but I will I was thinking all Boston, on 15 one 10, 2 amps, and 2 tweeters, that should get me pounding. If anyof you do have decent wattage in your systems, please do get a capacitor, they help save strain on your alternators, which after blowing 3 on my GTA, I decided it was time, at least after the first the next 2 werer covered under warranty.
Old Jul 29, 2006 | 06:06 PM
  #135
CaptainPioneer's Avatar
CaptainPioneer
^^^ Sorry i dont mean to be an *** but... There is NO WAY that you posted 153 on a Term Lab Mic... It just doesnt happen with Lanzar 15"s... Here is my reasoning... First off ur running 4 guage wire to a 1500 watt amp. standard there is a 0 guage, ur not providing enough power to it.... second Most Phoenix gold amps are over rated expecially if it is the Octane series... Yes Caps sometimes help to maintain a bass note that cycles deep and strains on the battery, but in reality it hurts your Alt any time... If anything get a High output Alt from somewhere. If you got a posting of 153 db on the old mic system (The ones currently used in most Car Audio shops those are off anyywhere from 3 - 8 dbs from the Term Lab.... Now if it was a Dash Reading Spl meter u can expect a whole lot less more like 10 -20 db off... I know because I thought my truck was loud when i first got it and then measured it.. only 134db i was extremely depressed totally thought i was hitting 150's. Then i got into a car that hits 150db on term lab... trust me its somethign that i would aim for some day. If my opinion doesnt matter to you thats fine but Im sure there are a couple of Audiophiles out on the Forum that will tell you that even in a Bandpass your not going to hit that number. As Habeba the Mod, we both have the same sub.
My current system: 2 Eclipse 9 series 12"s 2 cuft sealed box each chamber.
Pioneer DEH-P6500 Premiere HU
Crappy Crappy BOSS 1035D 1600 Watt amp (Real POS!!!)
Pioneer 6.5"s Premier in doors and 2 REV series in the coustom Fiberglass pods im makeing behind my head.
New System:
1 Resonant Engineering SX12 2x2 ohm subwoofer in a 2.5cuft slot ported box tuned to 35hz
Autotek mm1000 amp rated 1000watts at 1 ohm stable.
David Navone LOC (Line out Converter) using stock HU on Toyota Camry LEV6 2007
Future upgrades on the car will be 7" Midbass Drivers probably either Adire extremis or CDT Eurosports
powered by either an eclipse Amp or Autotek amp
Estimated SPL: 140db
Its not how many subs u have... its the quality, box size and engineering, and cleanest powere provided to the sub to make it really perform.
DODGEGIRL... U have 4 12"S in your truck? Do you have any pictures of it? I would like to see the configuration of that... Was thinking possibly of putting 2 more 12"s in my truck for my brother... he gets my truck when i get my new car
Old Jul 29, 2006 | 08:58 PM
  #136
DieselDemon's Avatar
DieselDemon
Hello folks. I have a 95' Ram, standard cab. Over the years I have made MANY mods to my truck. The latest was the stereo. I can tell ya what I did and and what I have learned. I am no expert but I think I have one of the loudest, and most crisp stereo systems on the planet. Here we go.
My head unit is an Alpine 9835
I have four (4) Infinity Kappa 6x9's (693.7I) One in each door, and one behind each seat. The rear are mounted in shallow 6x9 boxes stuffed with sound foam. My original storage system behind the seat has all been removed. I have also removed my center seat and console. Behind the two rear brackets for the center seat, I had enough room for a single Audiobahn AlumQ10. It is in a bandpass box and fits perfectly without a single mod. It is a dual voice coil with a 3 ohm rating each. This means I must have a 1 ohm stable mono amp
My Amps are as follows.
Infinity 7540A. In a 4 ohm load, this amp would put out 111 watts x 4 TRUE rms. (CEA compliant) Since my kappas are a 2 ohm load, they get pushed with 139 watts each. Alomost 30 watts over their continuos program rating. Remember, power doesn't kill a speaker. Noise and distortion do. The cleaner the signal, the better the system sounds. And good sound must be accompanied by power. Lots of it.
My sub amp is an MTX 6500D. I have three of these amps. 1 being used, and 2 brand news ones because they were discontinued. Just an AMAZING amp. My sub gets hit with almost 700watts. I personally feel that the Infintys are the best midrange/high speakers you can get, and the Audiobahns, to me anyway, have the best sound and mine gets a workout.
Both amps have high flow cooling fans. The infinity has 2 opposing fans that cool the "heatsink" tunnel, top and bottom. The MTX has a single 6 inch RV fan that powers up with the stereo. You can only hear the fan at low, low volumes. When is the volume ever low?
I have a custom wound, 208 amp alternator that I have NOT been able to max out yet. That's good.lol.
I used Monster brand hi shield tri-twist cables from the amps to the deck, and from my Sirius Sportster Replay, to the deck also. (single pair for Sirius)
I used Monster 12 gauge, heavy insulation speaker wire. From the amps right to the speakers. No factory wire was used at all.
Both amps have their own dedicated 4 gauge feeds from the batteries. Both are fused in the cab just before the amp, and right at the battery. Both amps have 4 gauge grounds as well. The Infinity amp has a 1.0 farad cap, the MTX has a 1.5 farad amp. Both the voltage displays have been disabled. Also both caps have 4 gauge feed, and 4 gauge ground wires. One amp is behind the driver, one behind the passeneger seats. Underneath each seat is a ground post. Each post handles one amp, and one cap, grounds. Under the truck I have 1/0 (1 ought) wire from ground post, to the frame. The frame has 6, 1/0 ground connections. There is one from each battery to the Cummins block, one from each engine ground post to the frame, and 2 more that go from the frame, to the SIDE post negative on each battery.
As far as all the different size wires go, I purchased a Thomas & Betts crimper that will do from 8 gauge, all the way up to 4/0. I stripped each wire carefully, soldered it full, and then crimped Phillips connectors to each. Then I shrink wrap all ends. My Ram is 12 years old and the original battery cables were lookin ragged. You can just imagine how fast my starter cranks now adays...lol.
There are some "stereo" standards that hold true.
1. Keep the power and signal wires apart from each other.
2. Make sure you wire size is adequate, if not, one size up from manufacturers specs.
3. Your connectors must be tight. Crushingly tight. Any slack between the wire and the terminal can create noise, and that will be where the first corrosion sets in.
4. Make sure you vehicles electrical system can handle the load. And if you're going to spend the money, save a few of them dollars for a quality volt meter. I used the Autometer Cobalt series 6391 to monitor my electrical system. if I have my stereo pumping, my AC on, my headlights, my foglamps, and anything else,...my voltage NEVER drops below 13.7 volts. It's rock solid.
I can "thump" if I need to, but since I hate that rap crap, I have my stereo tuned to give the best all around range quality. I get nothing but amazement from folks when they hear my rig. Guys find it hard to believe that all that sound is coming from a truck. My lights never flicker either.
Someday I will learn how to put a pic on here. Good luck to all. Ride safe.
Please forgive me if these do not work.
http://www.imageshack.us/user/dieseldemon
Ok guys, I really hope this works.....lol.
And one more thing. I know the wiring looks sloppy. I have not trimmed anything because all the power wires cost me a bundle. So I used it all. I will chop one end and crimp new when the new rug and seats go in. The wiring is top notch. I'll ziptie next week...lol
Now, a quick note about me and my attitude towards my truck.
First off, I am NOT a wash and wax guy. You can see by the pics there is dust, and some body work to be done. I have all new fenders, doors, panels, cab corners, etc. But right now I have ZERO desire to start it...lol. My first concerns are mechanical performance and vehicle reliability. I consider my beast to be one of the most mechanically sound trucks on the road. I use it like it was meant to be used
She tops out at 97mph, I don't push past that. It has horsepower and torque all day long. I know how to use those gauges for max performance. My pipe is an OLD MBRP stainless system that has a true 5inch downpipe, and is 5 inch all the way back to a 6 inch chrome tip. No muffler, no air freshener. Just a small resonator. She clouds all day long.
Other mods I have done are.
PDR HX40 Hybrid turbo
Bosch 370 marine injectors
#10 fuel place with 1 degree of advance. I have completely rebuilt my Bosch P7100. Nothing like spending $90 for a Snap-On delivery valve removal tool....lol.
Studded heads (ATS kit)
ATS 5 Star TC with Co-pilot
ATS 3 piece manifold (not on yet)
ATS fire ring cylinder head. (It's my original that I sent to them)
PDR intercooler boots
2 10 inch cab controlled pusher fans on my condenser. If I have to sit somewhere for a while, I use them for extra air movement when the A/C is on. Works AMAZINGLY well. An old fridge repair man told me to use that Robinaire fins cleaner. I do it at first spring, check the high and low side ports with a gauge, just to make sure she didn't loose that much during the winter. And then maybe once every 6 weeks or so. A gorilla like me can tell you when 3 BTU's are being lost due to inefficiency...lol. You don't think **** gets lodged in there but it's the oily greasy crap from the GM beater in front of you. By "beater" I mean anything that GM makes with a gas or Duramax engine.....LOL.
Autometer Cobalt series gauges with custom dimmers that I installed for each. I have four gauges mounted now but I have 5 more to install. Probably between the seats I will build a "monitoring center" and locate all the gauges there. I have actually been ticketed for obstructed view having my gauge pod on top. The judge tossed the charge. Stupid cop.
I have rebuilt both axles. The rear has a Detroit Truetrac, and I have a new Eaton E-locker for the front. I wish they made it for the back cause I give up a lot of rubber in exchange.lol
3 inch suspension lift by Tough Country
AGR steering gear
I have that steering stabilizer that mounts to the frame and stabilizes the steering gear shaft. I also have his tracbar adapater. Uses a 03? and up tracbar and gets rid of that factory ball stud JUNK bar. I can't remember the guys name, he was from Canada. PDR sells their stuff. The stabilzer works great.
208 amp alternator
God, there is so many more little things. I guess I should cover a few of the pics that I just posted.
There is my Infintiy Kappa 693.7I 6x9s. One in each door and one behind each seat.
A single 10 inch Audiobahn Alum10q between the seats. Obviously I removed the center seat. It's in that bandpass box in the pics.
You can laugh at my RV fan that I use to cool the MTX mono amp, but it works great.
The Infinity amp you can see the fans at the top left and bottom right. They blow air right down thru the heatsink tunnel. The amps never get hot.
You can see the two DUSTY capacitors.
And there is my Alpine 9835 hu.
My RF Limited Omegaforce S-45 Cb/Ham radio. I use a wilson magnettic on the roof.
The other two antennas are scanner and high band radio antennas.
My autometer gauges
And the two pics show the ground post behind each seat. The pic of the wire twisted into a pretzel is one of six (6) 1/0 grounds under the truck. I have regrounded every body panel as well with 8 gauge.
I crimp my own and use COPPER terminals only. I have made all new battery cables, and a new 4 gauge feed from the alt to the batteries. I got power all day long...LOL. She's a work in progress. EVERYTHING is relayed, and fused. The trigger wire from the hu activates a Bosch relay. The relay controls both amplifiers, the cooling fans, and a noise supressor. And just to make sure that you don't key up the cb while the amps are on...... it's relayed so that the CB and stereo cannot operate at the same time. I may just install a switch in the mic handle so I can listen while listening to both, and also have the safety of not keying up if I accidently go to transmit. My friends make fun of me cause I have chicken band. That cb has saved my *** PLENTY of times to the point where that radio has earned her keep...lol. SHE CAN STAY TOO!
Well, sorry it took so long. Hope this works cause my hands are about to fall off....lol. Talk to you guys later.
Big Ang
Old Jul 30, 2006 | 11:47 AM
  #137
CaptainPioneer
^^^ yea man i totally agree and thats awesome that u dont wax and wash!! I dont either though my rents get on my *** about not doing that lol hehe I topped out at 110 with my lil v6 goign down hill! lol
Old Aug 2, 2006 | 09:35 AM
  #138
HighDuke1911
Now that i have only part of my system, i'll add it to this thread. So... long story short, i have 2 infinity kappa perfect 10.1 subwoofers powered by the 2006 mtx tc6001 mono block amp. I am most likely getting a flip-out.
Old Aug 9, 2006 | 12:10 AM
  #139
joeyp1974's Avatar
joeyp1974
ive got a pioneer head unit stock speakers in my doors and a kenwood 600 watt amp with 2 10`s under the rear seat. i have to say it sounds great in the truck but you still cant hear it outside the truck.... prolly cause they are only 10`s, i need to upgrade the rest of the speakers.
Old Aug 14, 2006 | 10:41 PM
  #140
stealthguy's Avatar
stealthguy
All i have is 1 12 inch Infinity Subwoofer, 1000 watt Kenwood amp, Infinity Reference speakers in the back and front. It sounds great for what little is in there.
