Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Stock Sirius Antenna Adapter
Old Sep 2, 2011 | 02:06 PM
rweekley's Avatar
rweekley
Default Stock Sirius Antenna Adapter
Hello, I've searched the forum, but couldn't find anything. I have a 2007 Dodge Ram, with factory installed Sirius radio. Well as you know, you cant see the title of songs or artists on the headunit I have, so I am wanting to us an aftermarket Sirius tuner, a Starmate5. I have found the stock antenna plug behind the glove box. But my question is does anyone know of an adapter to go from the stock Sirius antenna plug, I believe the connector is called a FAKRA, and plug into the back of a aftermarket Sirius tuner, specifically a Starmate 5. Thanks!
Old Sep 2, 2011 | 08:08 PM
thunderhemi's Avatar
thunderhemi
you should be able to see the title and artist through your stock radio... in my 07 you just have to push the info button.
Old Sep 3, 2011 | 02:17 PM
rweekley's Avatar
rweekley
I don't have an INFO button on my radio. It is only a single disc CD player
Old Sep 3, 2011 | 10:36 PM
lxman1's Avatar
lxman1
Site Moderator
The single disc radio does not have this option. I bought the factory 6 disc radio from eBay and it was just plug and play.
There was on in our classified section not long ago.
You want a RAQ radio. I believe you have a REF now. The only bad thing is that it doesn't have the 3.5mm plug for a mp3 player like the one you have now, but I use a $10 FM transmitter for that. I rarely use it since I have a Sirrus subscription and 6 disc full of over 700 mp3's in the radio.
Sorry for the crappy pictures;
Old Sep 5, 2011 | 06:49 PM
rweekley's Avatar
rweekley
Thanks!
I found on another website, where someone used a GM adapter to convert XM antenna to Sirius antenna, already ordered the parts if that doesn't work, I will just send the parts back and get a RAQ radio.
Old Sep 7, 2011 | 05:45 PM
rweekley's Avatar
rweekley
FYI:
For anyone else looking into doing this,the GM XM to Sirius Adapter works , by connecting the stock Sirius antenna, the Fakra connector, to an aftermarket Sirius Radio.
Here is the link for that adapter:
http://www.tss-radio.com/products/gm...-adapter-cable
Old Sep 7, 2011 | 06:01 PM
dirtydog's Avatar
dirtydog
Moderate User
Thanks for the update. I gave this thread a Permanent re-direct so that anyone looking in the 3rd Gen area using search can see this indefinately!
