Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
air space under seat
Old Nov 29, 2011 | 06:27 PM
Thebigman's Avatar
Thebigman
Default air space under seat
So I would like to put 1 12" sub under my rear seats. Does anybody know what the total air space is under the seat from side to side? I understand that it will need to built using fiberglass. Also it depends on how high above the top of storage area you go. I just want a rough air space so that I can decide if its worth it for the sub I have. Thank you
Old Nov 30, 2011 | 02:38 AM
03gsxr's Avatar
03gsxr
i believe its 1.3 cubic foot i personally would run a nice 10" sub you wont be happy with i 12 I switched to a 10"
Old Nov 30, 2011 | 10:42 AM
Thebigman's Avatar
Thebigman
Yeah I am thinking about that but I love my 12 so I'm going to see what it can do! Thanks for the info
Old Nov 30, 2011 | 06:12 PM
lxman1's Avatar
lxman1
Site Moderator
Choke it is what it will do
Old Nov 30, 2011 | 06:29 PM
Thebigman's Avatar
Thebigman
I don't think so. I went into one of the car audio shops around here today and it just happens that they had a truck like mine with a 12 under the seats and it sounded pretty sweet
Old Dec 1, 2011 | 12:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
check out www.foxacoustics.com if you havent already. It might save you some time
Old Dec 1, 2011 | 07:38 AM
Bent's Avatar
Bent
you an apply active EQ to a sub. If the V/C is of sufficient structure then a L/T (Linkwitz Transform) circuit can be used to trade extension for output. An LT "fools" the driver into thinking it is in a different sized box by changing (in this case, lowering) the total system 'Q", Hoffman's iron rule still applies, but it's nothing that a well designed driver and excessive power can't overcome - but you'll still end up with the output of a 10" from your 12" this way.
