Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
aftermarket radio problem
Old Dec 10, 2011 | 06:30 PM
ah21283's Avatar
ah21283
Angry aftermarket radio problem
i put a flip out screen in my truck and it worked for about a day then, the sound just stopped workin randomly. then the other day i got out at the gas station and opened the door the radio worked, then when i closed the door it stopped workin again. then yesterday i floored my truck to pass another car and it started workin, then when i cranked the trcuk later it didnt work...... any help??
Old Dec 11, 2011 | 06:41 AM
scwpd's Avatar
scwpd
Sounds like you have a loose power or ground wire check to make sure they are all securely connected
Old Dec 12, 2011 | 01:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Originally Posted by scwpd
sounds like you have a loose power or ground wire check to make sure they are all securely connected
+1 .
Old Dec 12, 2011 | 11:11 AM
BWhelan's Avatar
BWhelan
It's funny that you say that you are having this issue because I have a similar one. I have a 2007 with a double dim dvd player. I never lose power on it, but when I roll my driverside windor up and down the sound flutters. If the window is rolled down to a specific spot it actually cuts the sound out all together, but the radio stays on.
I wonder if the radio shares any of the wiring as the power windows that could cause both of these issues?
Old Jan 7, 2012 | 07:58 PM
partyd's Avatar
partyd
3 cables in the radio harness have data, did you use the CAN buss interface to replace the radio
http://www.scosche.com/car-audio/product/510
