electrical system cant take it......
From what you have said, im almost 100% you have a bad ground somewhere. Maybe its not the battery or frame grounds. Maybe its not the HID ballast grounds. Maybe its PCM grounds.
Bottom line is IMO you have a ground issue. If you disconnect your amps and your HIDs and still have dimming of the lights and such then they are not the issue.
Thats not alot of power at all, I could see slight dimming but not that bad. What size fuse do you have at the battery for your amps? What brand and model amps are they? Put a multi meter at your battery and see what tour voltage drops too when playing....then turn your hids on and check again.
I dont remember on the fuses without looking. I think they are 25's. All the audio is name brand. Alpine amps. I havent done the voltage check yet but will get to it this weekend. Thanks for the suggestion.
