Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2004 1500 double din with infinity system
Old Apr 17, 2012 | 04:21 PM
boom38's Avatar
boom38
Default 2004 1500 double din with infinity system
Hello,
I am still confused as to what I need to install an aftermarket double din to be used with the factory Infinity system on my 2004 Dodge Ram 1500 manufactured 4-04. I have the bezel all ready to go from weedahoe. I have read quite a bit in the forums and on the internet and still not 100% sure. I have read about this ebay harness:
http://www.ebay.ca/itm/330511177394?...84.m1438.l2649
But have read that it may not work and would need a Metra CHTO-02 kit but have read that they distort your audio.
I don't really want to run new speaker wire to all doors.
If anybody out there with a 2004 has installed an aftermarked unit with the Infinity or if there is any tech guys let me know what you think.
Any help would be appreciated.
Thanks
Old Apr 19, 2012 | 05:56 PM
Dead2Fall's Avatar
Dead2Fall
Try a regular run of the mill wiring harness first. Mine was 03/04 and it worked without the need for any interface crap. Worst case, you're out the $15 for the harness. Best case it works just fine like mine did.
Old Apr 20, 2012 | 11:09 AM
John  M's Avatar
John M
Mine feeds speaker-level audio into a standard Dodge wiring adapter and it works great. This is an 03 w/ Infinity sound. My stock amp & speakers will really crank since my head unit has a crossover function that lets me cut all bass on those outputs. Then RCAs feed a separate sub amp and it all sounds surprisingly good.
Old Apr 20, 2012 | 12:02 PM
Dead2Fall's Avatar
Dead2Fall
Yeah keep us updated if you try it!
Old May 12, 2012 | 01:46 PM
boom38's Avatar
boom38
Well I tried the ebay harness last night and have no sound, so I guess I will have to order the Metra CTHO-02 interface.
Old May 12, 2012 | 02:12 PM
Ellis42's Avatar
Ellis42
Ok before you order the harness I believe when I installed my stereo I had to run two wires from stereo to one wire on harness, I had to put the power wire and the antenna wire together and then wire it to the power wire coming from the harness before I would get sound
Old May 12, 2012 | 02:21 PM
Ellis42's Avatar
Ellis42
Failed to mention I have an infinity system also mine is an 02 an I dont think anything changed from then to your 04
Post back and let me know if that worked
Old May 12, 2012 | 10:55 PM
boom38's Avatar
boom38
I tried that Ellis and no go, where the power antenna wire is on the harness where it matches on the oem plug there is no wire in that slot on my factory wiring.
Old May 12, 2012 | 11:07 PM
Ellis42's Avatar
Ellis42
No where the wires from the harness connect to stock wires from truck is were you connect both the power antenna and power wire coming out from harness to power wire from the truck itself
Old May 13, 2012 | 03:16 AM
boom38's Avatar
boom38
yes thats what i did and still nothing, I'm thinking I have a late model 04 which requires the Metra CHTO-02 interface.
