Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Radio connection question, '01 Neon
Old Mar 27, 2013 | 09:28 PM
edselsouth1's Avatar
edselsouth1
Default Radio connection question, '01 Neon
I have posted this also in the Neon section. I have a radio from an '01 Neon. The wiring diagram on the back (feed connector) shows the following: batt+, acc., illum., and park. Which of these is used as a memory. Can't seem to retain memory on the radio. Should the proper wire be hooked to 12v constant, or 12v switched? Thanks, David.
Old Apr 6, 2013 | 12:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
12v constant is always memory wire
Old Apr 7, 2013 | 12:21 AM
edselsouth1
Default radio connections....
Weedahoe.... Thanks for your reply. That's what I thought, but having to hardwire the '01 Neon radio into another make of vehicle confused me. Most assumed I was using the radio in an '01 Neon, w/ a factory harness. I probably didn't make my install too clear. Thanks, David.
Old Apr 7, 2013 | 01:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you need factory wiring info, check out www.the12volt.com
Old Apr 7, 2013 | 01:45 AM
edselsouth1
Default Radio connections...
Weedahoe... Thanks for the info. on the factory diagrams. I have looked at the site a number of times for factory connections, etc. Good for that, but not for putting an XXXX car brand radio into a YYYY car . The '01 Neon radio went into a '85 VW Quantum. VW sure can mess up some wiring (changes in colors from one end of the car to the other, etc. Thanks, David.
