Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Android 4.3 issues with Uconnect
Old Mar 29, 2015 | 12:17 PM
  #61
xsdbs's Avatar
xsdbs
Hello Durangomomma,
Can you tell me the Android version that is in your phone? I had thought that the S6 was coming out with Lollipop (5.x) which I have seen as an update in the Note 3 & S5, with that update Samsung did finally step up and fix the issue on their side. However I would still suggest having this TSB performed because there are a couple other enhancements that were made for network related issues.
To answer your question, yes I do believe that it will cure the issue. I'll see if I can find a friend that has rec'd the S6 and test it though just for my own satisfaction of knowing for sure. I thought that they were only a prepay unit and didn't know they were available already.
Originally Posted by durangomomma
Xsdbs, do you think this patch will work for the galaxy 6?
Does it also allow you to make outgoing calls without them dropping?
Has android, sprint or samsung addressed this problem?
