Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
amp for 2 sub wut amp?
Old Nov 2, 2005 | 08:13 PM
carlostheassin's Avatar
carlostheassin
Default amp for 2 sub wut amp?
ok, i need an amp or a bridged pair of amps for a pair of 12' rockford fostgate subs. subs are rated for 8 ohms? and 400 watts. has the 1.5 inch voice coil. i also have a 1/2 farad cap. but i just need to figure out an amp solution. anyideas on which amp. also how high of a difference can i have in the ohm ratings before its threatening to the hu or the amp or sub?
Old Nov 2, 2005 | 08:28 PM
techmanbd's Avatar
techmanbd
Default RE: amp for 2 sub wut amp?
I doubt it is 8 ohms. It is either 2 or 4 ohms. I am very partial to the infinity amps. Check this one out if you do have the 4 ohm. It is rated 426 Wrms at 4 ohms.
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF611A'&Ser=REF&Cat=AMP
Old Nov 3, 2005 | 12:35 AM
jeffs night out's Avatar
jeffs night out
First sell the rockfords and buy JLs or something. Then get a memphis amp like the 600d
Old Nov 3, 2005 | 01:57 AM
longislandboi85's Avatar
longislandboi85
i say you buy the first amp i told you about in the pm i just sent, screw the other amp. Use that one & it will pound.
Old Nov 3, 2005 | 02:43 AM
carlostheassin
yeah, the problem is im short on cash, i might try to talk to a guy i know and see wut he has, when i find out ill throw sum of those choices on there too
yeah the thign with the ohms is weird, i thought about it and 8 didnt seem right either, but i have a pic, and im almost positive thats 8 on the speaker cone. so yeah.. hm its a rockfordfosgate 12' punch series, if u wana look, they actually do have 8 ohm subs. but as for amp? yeah. lil confused, im also used to 4 ohms lol 8 is a lota resistance..
