Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2002-2005 FIBERGLASS DODGE RAM SUB ENCLOSURE BUY WHERE? HELP
Old 11-14-2005, 03:23 AM
biglg's Avatar
biglg
biglg is offline
Default 2002-2005 FIBERGLASS DODGE RAM SUB ENCLOSURE BUY WHERE? HELP
Hi,
I am trying to find where I can buy a sub enclosure to go under the rear seat of my 2005 dodge ram quadcab. I want to put at least 2 10 inch subs in the box. I have had the common mdf made box, where depth and speaker frame diamater size is limited due to the design of the inside of the box. My question is where can I buy a fiberglass box? Will the fiberglass box have more air space and allow me to install a sub with a larger frame. I have had a hard time finding subs to fit the MDF box, it seems most frames dont taper down quick enough. IF anyone has one they want to sell, or knows where I can buy one, or if someone makes them I am interested. IF there is a MDF box that has a different design than the common design you see everywhere, including ebay I would be interested in that as well. Any help would be appreciated. Thanks.
Old 11-14-2005, 08:43 PM
supergenius's Avatar
supergenius
supergenius is offline
Default RE: 2002-2005 FIBERGLASS DODGE RAM SUB ENCLOSURE BUY WHERE? HELP
make one..?
Old 11-14-2005, 10:57 PM
356MAGNUM's Avatar
356MAGNUM
356MAGNUM is offline
MTX Thunder forms This comes preloaded wit 2 10's. They even have a model that has a 200W amp.
Old 11-15-2005, 06:43 AM
supergenius
ORIGINAL: 356MAGNUM
how much?
Old 11-15-2005, 10:05 PM
356MAGNUM's Avatar
356MAGNUM
ORIGINAL: supergenius
ORIGINAL: 356MAGNUM
how much?
I out the part number in google, one site said list $369 for the loaded non amped
and garret store sells them for
DRQC20AC-T45 Loaded w/ two 10" Woofers / Amplified, Charcoal $415.00
DRQC20AT-T45 Loaded w/ two 10" Woofers / Amplified, Tan $415.00
DRQC20C-T45 Loaded w/ two 10" Woofers, Charcoal $316.00
DRQC20T-T45 Loaded w/ two 10" Woofers, Tan $316.00
Quick Reply: 2002-2005 FIBERGLASS DODGE RAM SUB ENCLOSURE BUY WHERE? HELP
