Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
amp and starting problems?
Old Mar 9, 2006 | 12:58 PM
Newneonguy's Avatar
Newneonguy
Default amp and starting problems?
Hi guys I am having a problem with my 95 neon not wanting to start very well after I installed my amp, I used 8 awg wire for the amp and that is also what is used for the battery. would this have anything to do with it all of a sudden not wanting to start very quick? should I rewire the battery to 4 gauge wire? well I hope I explained well enough for you all. thanks
Old Mar 14, 2006 | 04:46 PM
jktrepin's Avatar
jktrepin
Default RE: amp and starting problems?
If i were you, i would buy a compacitor, and check that out before you go rewiring stuff. Then your amp wont be trying to get power and it will start your car better. Kinda hard to explain i guess, but ya i would go with that.
Old Mar 14, 2006 | 09:21 PM
habeba86's Avatar
habeba86
If your amp is too big it could drain your battery enough to make it not want to start.. I would tell ya to get a deep cycle battery so it could hold a charge longer. Dont buy a cap.
Old Mar 17, 2006 | 03:09 AM
PEPPERHEAD's Avatar
PEPPERHEAD
Check the remote turn on wire for the amp and make sure it is wired to only have power when the ignition is on or ACC. And not a constant hot. That'll drain a battery for sure.
TASTE THE HEAT AND ENJOY THE PAIN
