Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
neons....
Old May 29, 2004 | 03:07 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default neons....
does anyone here have interior neon wired into the doorjam switch so they fade off and on like the dome lights??? im planning on trying this, hopefully monday...
Old May 29, 2004 | 11:05 PM
moparturd's Avatar
moparturd
Default RE: neons....
Don't forget to remove the feed from the original power source.
Old May 30, 2004 | 12:30 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i dont follow..i planned on splicing into the line fron the trigger in the door frame to the lights under the dash (since i dont have a dome light) so long as im downstream of the switch, i think it should work...or it wont...im gonna try to wire this at work monday...
yeah...work, at a garage from 7am to 4pm...
i think i wil change my oil...power flush my tranny...align the car...and run a 3 step engine cleaner, alogn with running some wires. all while getting paid, and using company supplies..
Old May 30, 2004 | 11:00 AM
moparturd's Avatar
moparturd
The "stock" dash light is hooked to ground, and a source be it a switch on the dash or whatever, it has a source currently. You need to eliminate the present source, so don't splice without disconnecting from the source. You don't want power to both sides of the switch.
Old May 31, 2004 | 02:52 AM
71RoadRunner's Avatar
71RoadRunner
I like this idea. That would be neat to have the neons fade just like the other lights.
Old May 31, 2004 | 06:54 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
well, i know one other guy who pulled it off with a 1g stratus....so hes somewhat consulting me on this...
and should it work,not only will it fade in, but it is attatched to my sunroof, and retracts with the sunroof...
Old Jun 1, 2004 | 04:42 AM
71RoadRunner
That's cool. So I take it that you are using the small neon trim type that is like a thick wire that car wrap around and all?
Old Jun 1, 2004 | 06:44 PM
techmanbd's Avatar
techmanbd
If that doesn't work where the voltage doesn't fade, you could probably use a capacitor and resistor from the power side of the neon to ground. This way the capacitor is charged during operations and when the power is lifted,ie turn power off, the capacitor discharges through the neon light, causing the dimming.
