Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
ad a amp to 2007 SLT
Old Nov 4, 2006 | 11:23 PM
2007 SLT Hemi Power's Avatar
2007 SLT Hemi Power
Default ad a amp to 2007 SLT
can I add a amp to my factory sirius radio in my 2007 SLT quad???, it is the 4 speaker system I believe, is there any connections on the back of this receiver?
Old Nov 6, 2006 | 01:31 PM
User's Avatar
User
Default RE: ad a amp to 2007 SLT
Do you have the upgraded system in the truck?
If so there is a stock amp, and if you replace the amp you are going to have to re wire the speakers, and why are you trying to hook an amp up to factory speakers/deck? It will blow the speakers.
and no there is no RCAs in the back of a factory deck, you are going to need a line out converter to do this. If you do this for about 2-4 months your system will sound good then the speakers will blow.
Its like putting +500hp to a stock tranny...
Old Nov 6, 2006 | 08:24 PM
habeba86's Avatar
habeba86
I agree!!! If putting in an amp upgrade the speakers, you will thank yourself!
Old Nov 6, 2006 | 11:20 PM
2007 SLT Hemi Power
thats what I figured, on well to Crutchfield I go..Thanks!!
Old Nov 21, 2006 | 03:20 PM
nash1970's Avatar
nash1970
Don't go to Crutchfield for your line control they only sell the Rockford one and it cost to much at my local audio shop they sell the Audio control LC6i for 150.00 it is a much better unit for adding amps to a stock head unit . I was gonna go that way but I did all the math and it didn't add up I would still have the stock H/U with limited features instead I got the Kenwood DPX501 .
Old Nov 21, 2006 | 04:17 PM
rtkota5point9's Avatar
rtkota5point9
$150 for a LOC?? That's ridiculous. You realize all it is is 2 capacitors and 4 resistors right? The variable ones use 2 resistors and 2 pots instead, but still. I make my own for about $5 with parts you can find at radioshack. $150 is crazy. And you won't blow the stock speakers with an amp. Only if you don't set the gains properly. It would be pointless really not to upgrade them, I'm not disagreeing with that at all, but you'll only blow them if you abuse them.
