Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2006 ram hu install question.
Old Dec 19, 2006 | 01:01 AM
t3k187's Avatar
t3k187
Default 2006 ram hu install question.
Hey guys need some help took out my h/u from my 02 ram and put it in the 06 and i get no power to unit at all. Checked h/u made sure no blown fuse or electric shock and it still wokring fine. get security light on h/u but no power to turn radio on, Hooked all wires to wiring adaptor acc to acc, bat to bat and gnd to gnd but nothign any ideas??
Old Dec 19, 2006 | 12:34 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: 2006 ram hu install question.
There is no acc (switched power) behind the radio in an 06. It's Can-Bus. You need to run a wire from the new headunit to the fuse panel or ignition column and get a switched 12V source there.
Old Dec 21, 2006 | 01:13 AM
t3k187's Avatar
t3k187
had one more question, With it needing a switchable source could i splice the ignition and acc wire and run it off the red wire from the wiring kit vs running another wire?
Old Dec 21, 2006 | 01:54 AM
habeba86's Avatar
habeba86
That would work jst fine for the acc wire.
