Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2003 QC new HU question...
Old Feb 27, 2007 | 09:53 PM
obsesseddodge's Avatar
obsesseddodge
Default 2003 QC new HU question...
I know this has probably been discussed before, but I've read and been told conflicting stories...
i'm about to upgrade to a aftermarket head unit, i have a 2003 ram 1500 QC with Infinity sound. My question is, since i ordered my HU from a online place, they are sending me the wire harness and mounting bracket, can i just install it with what they have provided?
I have been told about a "amp" in the glove box that needs to be bypassed or stripping out the entire system and just running wires with new speakers.....then i was told about some wire kit or harness that bypasses the amp????
i'm really confused, any help would be appreciated. []
Old Mar 6, 2007 | 06:02 PM
obsesseddodge
Default RE: 2003 QC new HU question...
TTT?
anyone....a little help please if ya don't mind, i'm really thinking of dropping the entire sound system idea...
if it helps, i'm thinking of adding a Pioneer 5900ib as a HU...
Old Mar 6, 2007 | 06:25 PM
kkuntz's Avatar
kkuntz
New Member
from my understanding/reading, you will need to bypass the amp or you'll speakers will sound like garbage. Run new wires from the HU to the speakers. Is there a 7th speaker? Last thing I remember was that 7th speaker gets ignored.
As far as a bypass adapter, I do not know. If there is, I would assume you'd have to hook it up to the inputs/outputs of the amp, in which can become it's own mess.
Or, just hook up your new HU and test it out without any changes to the amp[8D].
Old Mar 6, 2007 | 06:41 PM
rtkota5point9's Avatar
rtkota5point9
NO. You don't need to bypass the infinity system what so ever. It can be done later on if you decide to change speakers. It's absolutely not necessary on our trucks. I ran mine witht he factory amp for a long time. And the harness will be the same harness whether it's amplified or not, so the one they send will work. You just have to remember to hook up the blue wire on the new harness to the remote turn on wire on your new headunit. This is the factory amplifier turn on wire. If you don't hook this up you'll get no sound.
Other than that hook it up like a regular headunit in any other vehicle and you will be just fine
Old Mar 12, 2007 | 09:43 PM
obsesseddodge
cool, thanks guys for the info, the motivation factor just went up a notch!
Old Jun 24, 2007 | 12:42 AM
Sir Hardin Thicke's Avatar
Sir Hardin Thicke
ORIGINAL: rtkota5point9
Is this true with an 04 Ram 1500 also? I was just about to place my order for a new h/u when I was told that I need to run all new speaker wires to bypass the factory amp.
Old Jun 25, 2007 | 01:11 PM
rtkota5point9
Yes, exactly the same scenario.
