Help please.
Old Dec 22, 2012 | 11:07 PM
Marcus Kelly's Avatar
Marcus Kelly
Default Help please.
i need some help bad... my water pump seized up and i immediately stopped, i got a new water pump and put it in, truck will crank but wont turn over, i put a scanner or obd reader and it said error: camshaft position sensor or as the guys at the autoparts store called it a pickup coil which is located in the distributor so i got a new one. still wouldn't turn over, erased all the codes etc. was still not getting spark. i pulled the valve cover off and the rocker arms weren't moving. so i pulled the distributor cap off and the rotor wasn't spinning when i cranked also. pulled the bracket off the front, pulled the water pump off and removed the timing chain cover and both gears were broken as well as the chain. put all new ones on lined up the timing got a new cap and rotor. now I'm getting spark and HAVE been getting fuel but the truck still will not turn over my pcm is fine and working what else could this be? all the distributor cables are correct also? does anyone have any suggestions or tools of the trade to help me?
Old Dec 24, 2012 | 06:09 PM
lxman1's Avatar
lxman1
Site Moderator
Would be a bit helpful if we knew what the heck you were working on.
Old Dec 25, 2012 | 10:55 PM
highrevr/tflea's Avatar
highrevr/tflea
The motor seize up? My grand am chain broke and the motor went with it.
