Charger, Roadrunner & Superbee Talk Charger (pre-1975). Coronet, Roadrunner and Superbee (& other 'B' bodies) specific topics within.
Can any one help me with this question on swapping a 318 with a 360?
Old Dec 14, 2006 | 08:59 PM
1974DodgeCharger_SE's Avatar
1974DodgeCharger_SE
Default Can any one help me with this question on swapping a 318 with a 360?
I have a mint 1974 Dodge Charger with a factory 318 that I am going to replace with a 425 hp 360 V8 which I am currently building up. My car has a factory 727 Torq Flite tranny and I was wondering if i needed to make any modifications to the chasis to make this swap possible. Can any one help me please? Thank you all.
Old Dec 14, 2006 | 09:38 PM
TorRedOrv0436's Avatar
TorRedOrv0436
Default RE: Can any one help me with this question on swapping a 318 with a 360?
It should bolt right up as long as it is the same generation block. You didn't say what year the block was. If its the newer creat motor i would contact Mopar performace
, they should be able to help.
Old Dec 15, 2006 | 02:18 AM
71RoadRunner's Avatar
71RoadRunner
Yep, it should bolt right up.
Old Dec 16, 2006 | 02:14 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i believe that even with the newer magnum crate motors, the 727 will bolt right up..
Old Dec 19, 2006 | 04:51 PM
mr_mopar426's Avatar
mr_mopar426
as long as the units are the same lenth and width you should have no problems putting it in. The problem will be your stronger motor will effect the wear and tear on the stock unit and stock rear end. Both should be gone through to beef them up for the magnum motor. Brakes and torque converter need to be looked at too!! Have fun.
Old Jan 10, 2007 | 05:37 AM
unclemike's Avatar
unclemike
Different balance on the engine internals. I solved the problem with a B&M flexplate for 360 to 318 conversions. Also driver side motor mount might be different. The ears are closer together. Or is it the passenger side? I keep forgetting. If you have a 727 series Torqueflite you should have the heavier rear axle. Most 318 cars ran the 904 series Torqueflite from 1967 or 1968 up.
Old Jan 10, 2007 | 02:32 PM
1974DodgeCharger_SE
Thank you guys for all your help, I really do appreciate it.
I'll let ya'll know how it goes when its finished!!
