Charger SRT-8 That thing got a Hemi? Indeed, a 6.1L Hemi that is. The Dodge Charger SRT-8 pounds the pavement with severe power.
Brake dust
Old Mar 1, 2006 | 04:22 AM
425 hemi's Avatar
425 hemi
Default Brake dust
Just bought a 2006 Magnum SRT. After 3 days and 100 miles, I am noticing a lot of brake dust. I hear this is normal, however is there a method to limit this other then cleaning the wheels daily?
Old Mar 1, 2006 | 07:20 AM
MGDMike's Avatar
MGDMike
Default RE: Brake dust
I would suggest to quit braking! Honestly I don't know.. I've heard new stock pads produce alot of dust but I don't know...Welcome to DF and someone here is bound to have the answer!
Old Mar 1, 2006 | 03:57 PM
28this's Avatar
28this
Welcome to DF. Check out the marnum forum someone there probably knows something that works perfect for your car. One I have heard of is brake dust shields. I have seen them in parts stores, don't know how good they would be, never tried. Always thought they would restrict air across pads and make them hotter which leads to faster deterioration, but that's my opinion. It's something you can try if you want.
Old Mar 3, 2006 | 03:09 AM
Dartman69's Avatar
Dartman69
The fine folks at SRT have apparentally perfected a new brake pad compound that will be squeak AND dust free (well, not completely dust free, but alot better than what we're experiencing). According to our comrade 06MNRT, who has been corresponding with SRT, these new pads should be out in about 6 weeks once DCX has had enough time to muster up the parts.
Old Mar 3, 2006 | 05:45 PM
Bad Dawg's Avatar
Bad Dawg
Default RE: Brake dust / blue smoke @startup
I am new to the dodge forum.Just purchased an '06 magnum SRT8........needless to say ,it HAS in fact surpassed all of my expectations. I'm looking for the latest info on the brake pad fix anmd also have a question to anyother 6.1 L SRT8 owners,I've got a thousande miles on my MAGNUM and when I start her up in the morning I get a small blue cloud of smoke ??? anybody else notice this ?
Old Mar 3, 2006 | 07:13 PM
06MNRT's Avatar
06MNRT
Blue cloud of smoke? That is not normal and you should go see your dealer immediately.
The brake issue is about 6 weeks from a fix.
The brake dust will most likely always be an issue to some degree because high performance brakes do create a lot of dust. Any system, on any car, that's just the way it is.
Follow the other threads on this matter to keep abreast of the resolution.
Old Mar 6, 2006 | 05:47 PM
eddiev56's Avatar
eddiev56
Will we have to pay for the brake fix or will the dealer be notified and take care of the problem?
Old Aug 30, 2006 | 07:10 PM
devans27's Avatar
devans27
The blue smoke at startup IS normal if you press the accelerator before you crank. tip, don't press accelerator before start and you'll never see smoke until you wear out rings.
Old Aug 31, 2006 | 03:56 AM
vantageid's Avatar
vantageid
I dropped my Magnum SRT8 at the dealer two days ago for the Service Update (not a recall) for the brakes... ie. slotted rotors and different pads, which costs nothing. As luck would have it, upon arrival to pick up the car today I immediately noticed the lack of slotted rotors!? The dealer installed the wrong rotors, in fact they (re)installed new but standard rotors. However, they did install upgraded pads! Hurray. They were pretty embarassed that I was the one to point out the problem, a bit disconcerting none the less. As consolation they let me keep my Dodge/Chrysler Sebring loaner for another day, thanks Dodge.
Old Sep 5, 2006 | 12:58 AM
roadbone's Avatar
roadbone
I'd like to know which dealerships just install these parts without hassle,the ones I go to it's a fight just to get them to beleive that I have a noise coming from the front left brake.....
