Dart, Demon, and Duster Talk Dart, Demon, and Duster (& other 'A' bodies) specific topics within.
big plans for my 76 dart sport
Old Oct 19, 2012 | 02:00 AM
fordb7976's Avatar
fordb7976
Default big plans for my 76 dart sport
This is my first forum, and I'm posting from my cell phone, so spelling might be bad. But I'm curious, I have a rolling 76 dodge dart with no body work that needs done, but it needs a motor and Trans. I have a 318 and 727 Trans out of a 79 4X4 power wagon 1/2 ton. Can I swap out the tail end of that Trans by removing the transfer case and slapping on the trail end of a two wheel drive Trans? And for the 318 motor I have 340 heads (the ”X” heads with bigger valves) and a camshaft with a double timing chain that came with the heads, I wanna know if those heads will drop my already low compression and if there is a good easy solution to make up for that compression loss, like turbos? Or shaving the heads a little? Idk. Just trying to work with what I got. And how about piston to valve clearance? Will that cam push those valves into my pistons? This is gonna be my first engine build so I'm not too sure. I'm just going for a slightly Better than stock 318 with the few parts I got laying around.
Old Oct 21, 2012 | 11:59 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the muscle section.
Old Oct 25, 2012 | 07:48 PM
fordb7976's Avatar
fordb7976
Sounds great. Thanks
Old Nov 2, 2012 | 02:18 PM
lxman1's Avatar
lxman1
Site Moderator
You will need the specs of the cam to determine p to v clearance. Just be sure to use new lifters because used lifters on a used cam usually results in a flat cam lobe unless the lifters are put back onto the same lobe that they were on originally.
I would doubt that the X heads have a larger CC than the 76 heads so a drop in compression is highly doubtful.
Old Nov 5, 2012 | 09:18 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
A competent machine shop should be able to build it for you for a couple thousand.
FF
Old Nov 5, 2012 | 08:18 PM
fordb7976's Avatar
fordb7976
So what I'm looking at for duration and lift on the cam I want to use is a duration of 268/272 and a lift of 0.429"/0.444" the stock 318 cam however is at a duration of 240/248 and a lift 0.373"/0.399" having never built an engine from nothing but parts, I'm only vaguely aware of what that means as far as piston to valve clearance. I'm just assuming more lift and duration means more power.
Old Nov 6, 2012 | 09:03 AM
1969CoronetR/T
vaffanculo
Old rule of thumb for HP engines is 284 degrees and .485 inch lift so a smaller profile should work.
FF
Old Nov 17, 2012 | 09:38 PM
fordb7976's Avatar
fordb7976
FF
Awesome! Now I know.
