Notices
Detailing Discuss detailing your ride inside and out here.
gauge overlay
Old Dec 6, 2007 | 12:32 AM
slugshot_90's Avatar
slugshot_90
Default gauge overlay
i was wondering if anyone knew how hard it was to change the guage overlay in yor car
Old Dec 6, 2007 | 01:23 PM
Bunky's Avatar
Bunky
Default RE: gauge overlay
What part are you talking about ? The clear front or the surface the nomenclature is printed on?
Old Dec 6, 2007 | 04:56 PM
bad venge's Avatar
bad venge
Section Moderator
It depends on your car ... most require removing the instrument cluster, then some will require needle removal , if needle removal might require recalibration of the speedo as well as reseting all the other needles ... Some can be slipped over the needles then secured by double backed sticky tape or screws...If they are intelliglo or lighted might require electrical connections
Old Dec 7, 2007 | 07:54 AM
slugshot_90
i was takling the about the actual gauges i wanted to put white gauges in
