Notices
Detailing Discuss detailing your ride inside and out here.
The advantages of (APC) Acrylic paint conditioner over Wax
Old Apr 6, 2010 | 04:44 AM
ShocK's Avatar
ShocK
Default The advantages of (APC) Acrylic paint conditioner over Wax
If you have ever wax a car on a regular basis you have a much better understanding of the pros and cons of Wax. And it seems that very few people understand that there is a fundamental difference between wax and polish. Basically Wax is a covering and polish is an abrasive cleaner.
Today the word polish can be used to describe anything that will put a shine on something.
The Acrylic paint conditioner is neither polish or wax. It is designed to work from within the paint rather than on top.
1. Never Dulls
2. Can be applied in hot sun
3. Can be applied in freezing temperature
4. Does not yellow
5. Does not have to be removed
6. Requires no buffing
7. Does not harden
8. Does not create swirl marks
9. Pure liquid
10. Rust resistant
11. Easy one step application
12. Eliminates the need for Clay
13. Eliminates the need for polish
14. Creates a shine within the paint
15. Is absorbed into the paint
16. Creates no debris or waste
17. For “Scratch Shield paint”
18. Preserves factory finish
19. Does not trap and hold particles
20. Has built in cleaning agents
21. Eliminates the need for soap
22. Protects Chrome & wheel from road salt
23. Conditions and shines black vinyl trim
24. Conditions and preserves clear headlights
25. Deoxidizes and restores color to acrylic paint
26. Conditions & replaces essential elements in paint
27. Takes less than a half an hour to apply
28. Unique in the market
29. Non abrasive
30. Efficient, 95% goes in the paint 5% in the towel
By comparison 'wax
1. Dulls
2. Cannot be applied in hot sun
3. Cannot be applied in freezing temperature
4. Yellows
5. Must be removed
6. Must be buffed
7. Hardens
8. Creates swirl marks
9. Solid and solids suspended in liquid
10. Has no rust inhibiting properties
11. Two stage application
12. Creates a need for clay
13. Creates conditions that require polish
14. Creates a wax shine on top of the paint
15. Sits on top of the paint
16. Wasteful and messy
17. Not for “Scratch Shield”paint
18. Replaces factory finish
19. Traps and holds particles
20. Has no built in cleaning agents
21. Creates a need for soap
22. Designed to be used on painted surfaces
23. Not designed for use on black vinyl trim
24. Has no conditioning effect on headlights
25. Is not a deoxidizer or color restorer.
26. Does not condition paint
27. Can take hours to apply
28. Common in the market
29. Can be abrasive when hard
30. Inefficient 95% winds up as waste
Source:
http://www.ibc34.com/VaporWax.html
Old Apr 6, 2010 | 08:03 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I use a paint sealant then a coat of wax after the sealant cures for a day. All of this after I clay and polish the vehicle,
FF
Old Apr 7, 2010 | 02:24 PM
Pro-Techt's Avatar
Pro-Techt
Hey ShocK - Is your real name Jerry Pittman?
Old Apr 8, 2010 | 08:37 PM
Bunky's Avatar
Bunky
It is amazing how someone tries to sell a sealant as it was just invented. There are many sealants (do not contain natural waxes) on the market.
Old Apr 14, 2010 | 01:05 AM
ShocK's Avatar
ShocK
True the market is full of sealants that do not contain wax.
Vaporwax is not a sealant, it is an acrylic paint conditioner (APC).
It functions quite differently. Closer to a sun screen than a sealant.
There is no other company in the market that makes an acrylic paint conditioner.
Acrylic paint conditioning is somewhat new, it was introduced in 2007 three years ago. Developed by the same company that makes Pittman ALR, another product that is unique in the market, introduced in 2005.
VaporWax is not a wax covering, abrasive polish, or paint sealant.
Old Apr 17, 2010 | 10:47 PM
ShocK's Avatar
ShocK
FF
What are the advantages to using a sealant before applying wax?
How long does it last?
Is it applied before each wax job?
I was under the impression that you would:
1. Clay
2. Polish
3. Clean
4. Wax or Seal
Actually I am confused on that whole clay and sealant process.
Old Apr 18, 2010 | 09:02 AM
1969CoronetR/T
vaffanculo
Paint sealant will last 6-12 months as wax will only last 2-3 months at best. Claying will make the car smooth as glass for better adhesion of the sealant or wax. Run your hand on your rocker panels or lift gate (such as a Durango) and it will feel like sandpaper, even after the vehicle is washed. The clay will take that embedded material off and the end result is very noticeable. It can also prevent the polish from picking up fine material and scratching the paint. I can clay my Durango in a half hour so it is not as time consuming as polishing,
FF
Old Jun 21, 2010 | 02:18 PM
ShocK's Avatar
ShocK
FF
I believe you about the rough feel on the paint.
I am a firm believer that the use of clay is necessary when wax is used on the car. I never use wax and I never had a need for clay.
There is no rough feel on my paint as you described. in fact it's slick.
I think as long as you use wax you will have a need for clay and a lot of other wax related products and tools
Buffers
Cleaner wax
Polish
Soap
etcetera.
I think if you like to buff and polish your paint then the use of wax is ideal, It will keep you busy.
When I was younger that was OK but I don't the time, energy or desire to stand out there and rub and buff on a car for hours.
But over and beyond that, I want to keep my paint looking new and I know from experience that wax, clay and polish won't do it.
Old Jul 17, 2010 | 05:33 AM
darthroush's Avatar
darthroush
Section Moderator
Now I get the point of all the other posts...to set-up why everyone needs to buy your stuff.
Old Jul 17, 2010 | 10:45 AM
ShocK's Avatar
ShocK
Thats a nice looking dodge.
Those models are notorious for headlight fogging'
Have you had to clean them yet?
If so, how long ago and What do you use to clean them?
