Meguiars Headlight Restoration Kit
Yes it works. It's not hard. You can use sandpaper and water and the use a polish like rubbing compound and it's the same. the toothpaste trick works also. It was shown on a episode of "TRUCKS". Just use plain old white toothpaste and a rag and then polish it!
Meguiars is a popular resurfacing kit but resurfacing may be more than what your headlights need.
If your headlights are damaged, scratched or scraped a resurfacer would be the way to go, however thats rare.
Oxidation is the most common cause of cloudy and yellowed oxidation. In those cases an acrylic lens deoxidizer will clear your lens up fast and because it's target specific liquid, there is no risk of causing further damage to the surface or UV protective layer.
It does take a measure of skill to use any multiple step kit. That's one reason why results can vary. The worst kits are the hand sanding kits, they almost always give bad results.
Trending Topics
In extreme cases, sanding is the only way to get the job done -- where the factory coating is blistering or peeling, the only way to adequately repair the lens is to remove the coating with sandpaper.
If a sanding kit gives bad results, it's usually a matter of technique on the part of the operator, and can always be fixed.
Always follow restoration with either routine polishing, a sealer, or a lens protection kit.
