Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Buying My First Truck
Old May 28, 2013 | 11:45 PM
clarkd1990's Avatar
clarkd1990
Default Buying My First Truck
Hello,
I am looking at buying a Dodge Ram 1500 for my first truck. I am just wondering if anyone has any hints or suggestions on models or years that are best.
I will be using the truck for basically if I need to throw anything in the back. I wont be towing huge loads with it and I am looking for a quad cab.
Thanks
Old May 29, 2013 | 10:50 AM
abdodge1500's Avatar
abdodge1500
Is this a brand new truck or a used truck? In a 2nd generation ram (94-01) I would avoid the ram with the 3.9 v6 because its underpowered and gets about the same mileage as a 5.2 v8. Other than that I would try to find a truck that's been maintained regularly and you've got nothing to worry about. Try to find a truck that hasn't been someone's play truck that they just beat up and don't care if it breaks.
Old May 29, 2013 | 10:52 AM
abdodge1500
Also if its a 2nd gen gasser, ask the seller about the plenum gasket issue and if the truck is experiencing it or if he's fixed it. It's a pretty common issue on these trucks.
Old May 29, 2013 | 12:02 PM
Jigabop's Avatar
Jigabop
why is this post in the cummins section...they don't make a 1500 cummins
and that new 1500 diesel is NOT a cummins...
