Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
97 2.5L. Is it ok to drain and refill my tranny fluid w/ new fluid?
Old Dec 6, 2009 | 08:07 PM
v6avenger09's Avatar
v6avenger09
Question 97 2.5L. Is it ok to drain and refill my tranny fluid w/ new fluid?
I dont think it has ever been changed and my avenger has 160k on it. the fluid is reddish brownish (not as red as it should be) and doesnt smell burnt, but i want to start fresh. I read somewhere that a fluid change can ruin it because of the grit in the fluid from use is actually what is keeping the tranny going and without it, it would just slip because it is so worn down. Is this true? Can I change the fluid?
Old Dec 6, 2009 | 08:47 PM
bad venge's Avatar
bad venge
Section Moderator
I would change it but suggest dropping the pan AND change the filters
Old Jan 19, 2010 | 11:18 PM
juanlanas13's Avatar
juanlanas13
Also make sure you put the right fluid back in.
