Dodge Avenger This forum hosts discussion areas for both the 95-00 and 08-14 Dodge Avenger Coupes and Sedan
Problems shifting
Old Jan 19, 2010 | 11:11 PM
juanlanas13's Avatar
juanlanas13
Angry Problems shifting
I have a 96 dodge avenger es 2.5, it seems to take a long time to shift out of first gear i have to realy step on the gas but after that it shifts fine and it dosent happen all the time, when i first get in the car it shifts fine but after like two stops it starts but when i turn the car off it and restart it it the same thing happens again. I have replaced the trans filter and fluid with atf +4, input sensor, solenoid pack and i have a rear motor mount on order can some one please help me. Thank you.
Old Jan 21, 2010 | 09:31 PM
bad venge's Avatar
bad venge
Section Moderator
might be the TCM or an internal trouble
Old Jan 21, 2010 | 11:19 PM
juanlanas13
I replaced the rear motor mount and now it is working fine, thank you for your help.
Old Jan 22, 2010 | 04:25 PM
juanlanas13
OK i guess not worked good for one day, no problems, drove it this morning and it all started again.
Old Jan 22, 2010 | 07:27 PM
92dak5.24x4's Avatar
92dak5.24x4
without proper diagnostic equipment, it's a total guess. As you found out with the parts you already changed and that didn't fix the problem. I highly doubt it's a bad computer. This kind of stuff is indicative of internal issue
Old Jan 22, 2010 | 08:31 PM
juanlanas13
Im going to take it to the tranny shop tomorrow, let you know how it goes, thank you.
Old Jan 23, 2010 | 08:59 PM
juanlanas13
Ok took it to the shop they retrained the tcm and also said that i have a misfire, car still runs the same took it to my buddys house and we checked it over and found it not to be a miss but a bad fuel pump, his friend which as been a mech. for a long time and has a shop also said it was a bad fuel pump. just for got to ask him is a fuel pump for a 2.0 will work for a 2.5 eng dose any one know.
Old Jan 29, 2010 | 09:35 PM
juanlanas13
It was the fuel pump replaced it a couple of days ago and it is still shifting good and runs and idles better.
