avenger code reset/washer fluid light
2 more things then I'll stop. I reda somewhere,but can't find it, that if you remove the battery the codes will reset but that you have to clean something or the idle will be bad? it erases the idle memory? also my washer fluid resovior is full but the idiot light stays on any ideas?
Idle Air control can cause a bad idle as can a bad EGR valve ... disconnecting the battery won't cause these to be bad or cause a bad idle...
resevoir theres a sensor that gets coated overtime remove and clean
okay on the washer fluid res. I see the pump at the bottom, and a wiring connector at the top, which one has the sensor? probably the bottom, looks like i gotta take off the master cylinder?
i got the new map sensor and this baby rides great, i can't believe the diff from just one lil sensor. previous owner stated he tried to mess with the idle, don't think u can short of jerry rigging the cable. but what should the idle be at in park and drive? seems low to me. i could get a new iac if needed.
alrite now what the heck.....I told you about the low idle not a big problem just have to 2 feet it till i can get a chance to look at it. but on my way home just now, it stalled. i restarted it and it ran sluggish for like a second, after hittin the gas a little the check engine light came on and it started running like it did when my map sensor was bad. i get home key dance it and im gettin a 12-13 again map sensor?!?!?!?!? i cant afford to replace these every couple days any ideas?
