Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Transmission
Old Jan 17, 2009 | 06:53 PM
morepower29's Avatar
morepower29
Default Transmission
Does anyone know how to check and change the transmission fluid/gear oil or whatever is in the cvt tranny of a 07 caliber?
Old Jan 17, 2009 | 07:18 PM
bigtsr's Avatar
bigtsr
The CVT inspection access is just below and to the left of the battery.You can see
the screw off cap but there is no dipstick supplied.The inspection of the fluid is
designated as a dealer function,the fluid itself is expensive and is composed of
a combined fluid and a special composite rubber like substance.
The fluid check itself involves temperature readings as well as volume.
Check your owners manual for the service schedule.The CVT is non repairable
at the dealer level and if need be is replaced as a whole unit.
Old Jan 17, 2009 | 09:51 PM
lxman1's Avatar
lxman1
Site Moderator
Yep, the dealer can check the fluid with a Starscan tool I think. Amazing
Old Apr 2, 2009 | 09:48 PM
lxman1's Avatar
lxman1
Site Moderator
Had mine checked at it's first oil change a couple of weeks ago. It needed a little topping off (factory likes to short change fluids). Less than 1/2 qt. The tech said DAMN,, that stuff is $27 a qt!!!!
