Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
caliber engine light
Old Sep 21, 2009 | 03:51 PM
jrs67800's Avatar
jrs67800
Default caliber engine light
had my engine light come on last week took it to a local auto zone and they checked it out for me said there was a small emisions leak suggested t i replace the gas cap said it might fix the problem a few day later light was off. just last wed light came on again to i to local midas shop they also said small emisions leak said there was something about a faulty hose said he checked it and it was fine. started the car this morning light came back on any ideas would be helpful........ thank you.
Old Sep 21, 2009 | 04:28 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum.
It is losing pressure in the evaporation system somewhere.
I have also seen evap codes if you over fill the tank. Pumping after the pump kicks off the first time, but usually not that code.
If you replaced the gas cap already, it is either in a hose or the canister itself usually.
Old Sep 26, 2009 | 04:01 PM
TUNDRA_schumacher's Avatar
TUNDRA_schumacher
Our R/T has been in the dealership 3 times for the "mystery engine light" and they haven't been able to fix it yet. It's not on all of the time, but it comes on and off. Usually depends on if it's been raining.
We just ignore it now.
Old Oct 30, 2009 | 11:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
If you are getting a small evap leak, the scanner can not run a small leak test. If you have an NVLD pump have it replaced.Maybe warranty.If you have the ESIM pump, replace it and the canster.Also maybe warranty.Also ck for flash updates too.
