Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Aftermarket Stereo install help
Old Apr 14, 2010 | 04:28 PM
lxman1's Avatar
lxman1
Site Moderator
Less to go wrong I guess
Old Apr 15, 2010 | 03:50 AM
X3r0a1m's Avatar
X3r0a1m
True but i was hoping to be lazy on this car and be able to have cruse control and not have to use a key to unlock my door lol
Old Apr 15, 2010 | 09:20 AM
KRZY.BMET's Avatar
KRZY.BMET
Peaceful Browser
Your radio will need that bypass part for the radio to work, however the price that that is at is high.
I had my Radio Installed at Circuit City and the bypass harness was only $24. The only thing was that the radio doesn't do that stay on till the door is open thing, but I didn't care. I shut the car off, I want everything to shut off.
Your stock radio is tied into your computer and that is why you need that part.
If you already have the mounting kit, and wire harness, I'd just take it to Best Buy and let them finish the install. They will have the bypass harness. Best Buy charges $50 for a head unit install plus parts. If you don't get that part, you may end up with the CEL being on because it doesn't see the radio.
Old Apr 16, 2010 | 09:38 PM
lxman1's Avatar
lxman1
Site Moderator
Good info. Thanks!!
Old Aug 10, 2010 | 11:46 AM
Milillo02's Avatar
Milillo02
Default boston system
im having a problem from my local best buy were they cant seem to install it right. The problem im having with their harness is that my factory speakers work occasionall y not all the time with an aftermarket kenwood unit. The last post said something about an extra bypass harness of 24$....what exactly am i bypassing with that? anyione else having this same problem with an aftermarket head unit? i did buy the best buy harness of 124$ but that is still not working properly.
Old Aug 10, 2010 | 04:10 PM
lxman1's Avatar
lxman1
Site Moderator
The harness mentioned above, fools the computer into thinking the stock radio is there and takes away the computer control of the head unit.
Do you have other speakers hooked up as well? Do they always work? Sounds like maybe you got a had harness that may have a bad connection or wire somewhere.
Oh yeah, welcome to the forum.
Old Aug 11, 2010 | 07:01 PM
Milillo02's Avatar
Milillo02
i do have two alpine sub woofers and an amp connected to the headunit, but no extra speakers, just the oem 9 speakers from the car. my local best buy dosnt know anything about a bypass harness. do you have any links of where i can buy iyt and what exactly is it bypassing? they tried installing another wire harness behind the aftermarket headunit but no help still does the same thing. im guessing i need this extra bypass harness?
Old Aug 13, 2010 | 10:10 PM
lxman1's Avatar
lxman1
Site Moderator
Originally Posted by X3r0a1m
Peripheral C2R-CHY4 Radio Replacement Interface for select 2004-Up Chrysler/VW
http://www.discountcarstereo.com/detail.aspx?ID=1173
That there is the part i need. the store here sells it for 125 but just now found it cheaper online. going to print out the page and show it to them maybe i can get it for that price or less
Might check this part out mentioned here or check with www.crutchfield.com They have excellent customer service.
