Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
55K miles - small issues, questions!
Old Oct 26, 2011 | 12:58 AM
carrevan's Avatar
carrevan
Wellllllll....
It's not the Fuse... and it's not the cup holder lights (aftermarket, I had to replace and rewire). Even the dimmer switch doesn't kill the issue... I don't want a ghetto Caliber !!!
Old Oct 26, 2011 | 06:02 PM
lxman1's Avatar
lxman1
Site Moderator
Do they dim as they should, but still flicker?
Old Oct 27, 2011 | 10:14 PM
carrevan's Avatar
carrevan
Yeah. It'll dim fine but still will flicker. Sometimes when it's on the lowest setting it will flash to the brightest real quick. Rather annoying. If the Caliber wasn't pieced together like legos I would take a screw driver to it.. but there are no screws!
Old Oct 29, 2011 | 12:51 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like a cluster problem if the HVAC controls do not flicker. Maybe a bad connection at the cluster plug or possibly a weal ground.
I haven't had to rip into mine yet, so I'm not sure how the Lego pieces are snapped together.
Old Oct 29, 2011 | 02:07 PM
steak59's Avatar
steak59
You have to remove the Upper Dash to get the cluster out. it is very painful.
I never seen a flickering cluster on caliber b4. But this sounds like a cluster problem if no other lights flickers.
