Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
P0445 and P0446 code help
Old Mar 10, 2012 | 02:27 PM
BRay09's Avatar
BRay09
Default P0445 and P0446 code help
I have a 2007 dodge caliber with the 2.4L 4 cyl motor. It is idling at aroung 1500 rpm. it has around 66k on it. I scanned the codes and it came up with the 445 and 446. Should i replace the canister purge valve or be looking into the wiring harness to it? Where is it located exactly?
Old Mar 11, 2012 | 05:18 PM
lxman1's Avatar
lxman1
Site Moderator
I would start with the gas cap. This is usually 99% of the 445 code. It doesn't seal properly ad causes the massive pressure loss code.
A code P0446 could mean one or more of the following has happened:
* Faulty vent valve
* Open, short or excessive resistance on Vent valve control circuit
* Blockage of vent valve
* Bad PCM
I would replace the gas cap first, reset the codes and see what happens. It's the cheapest route.
Old Mar 12, 2012 | 10:56 AM
BRay09's Avatar
BRay09
We have replaced the gas cap about 6 months ago when we got an evap code for a small leak. Codes were erased and haven't came back on since. This came on Friday. I don't understand why it would make the vehicle idle high
Old Mar 13, 2012 | 04:12 PM
lxman1's Avatar
lxman1
Site Moderator
Not sure either, unless there is enough extra air being drawn in to cause the high idle.
Old Mar 14, 2012 | 06:54 AM
BRay09's Avatar
BRay09
Where is the purge valve located at on this motor
Old Mar 16, 2012 | 09:32 PM
lxman1's Avatar
lxman1
Site Moderator
I believe that the valve is at the canister near the fuel tank.
Download this free service manual and it will be quite helpful.
http://www.mediafire.com/?4d7adjtcyzdrcez
It is legit, it was uploaded by a former admin here.
