Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
TPMS is confused
Old Nov 28, 2012 | 03:52 PM
methpmp's Avatar
methpmp
Default TPMS is confused
Okay I hoping for some feedback here so any tips would be great...
I have an 08 caliber SXT 1.8L with the 5 speed that has 63k miles.
I was out today looking at tires and the counter dude and i were chatting about the CHECK TPMS error code im getting on the Evic dash and how when it comes up everytime i turn the key on it'll show that and then goto the tire pressure display where it will show all 4 tires current pressure reading.. .. it thought that it was weird that it would say an error but show all the pressures and they were all the same except for a tire with a slow leak.. So he went in the store and got out a reader and he said that the TPMS has 5 codes currently being thrown ..
C0077- LOW TIRE PRESSURE
C151D-TIRE PRESSURE SENSOR LOCATION UNDETERMINED
U1114-LOST COMMUNICATION WITH LEFT FRONT TIRE PRESSURE TRIGGER MODULE
U1116-LOST COMMUNICATION WITH LEFT REAR TIRE PRESSURE TRIGGER MODULE
U1117-LOST COMMUNICATION WITH RIGHT REAR TIRE PRESSURE TRIGGER MODULE
At that time all tires read 30 psi except one that read 23 due to a slow leak....
What im confused about is how can they show pressures that if they all have lost signals and what would cause all 3 of them to loose communications ... and the stealership wants $100 bucks to just hook up to the computer when the tire place did it for free
Old Nov 28, 2012 | 07:30 PM
lxman1's Avatar
lxman1
Site Moderator
Sounds like maybe your sensors have failed?
You may try unhooking the battery for about an hour to reset the PCM and see if that does any good.
