ac noise
hi every one i hope i am in the right place.i run the water pump,power steering,
alternator and ac all separate and ac is making laud noise.can i replace the clutch on the ac compressor?
Welcome to the forum.
How did you run them separate? Most of the time, the noise is actually the one way clutch pulley on the alternator.
I am sure not sure about the clutch. These compressors are variable depending on system pressure and do not clutch cycle like most vehicles.
ok i took the serpentine belt off and i use a leather belt about 3/8 tickness
with a clip, i cut the belt to fit from the damper to the pulley of each parts
using just little tension on the tensioner because the clip is not very strong
No clutch replacement. VDOT compressor are controlled by changing displacement internally. They are replaced as a unit.
But these compressor has fairly low failure rate tho.
does the noise change with A/C ON vs A/C off?
Trending Topics
thank you for the info steak59
thank you steak59:
this comfirm that i pick the bad apple of the barrel
first a tire pressure sensor 2ea then the horn,control arms 2ea
window control ,and cruze control still not working.ha ha it hurts...
