Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
Rear Left brake/indicator/tail light not working
Old May 6, 2013 | 02:09 PM
dona_moyer's Avatar
dona_moyer
Default Rear Left brake/indicator/tail light not working
Hello, as I have just registered for this forum, this is my first post... The left tail and indicator and brake light are not working on my 2008 doge caliber. I suspect a burnt out fuse, but am unsure what it would look like. I think the fuse box is under the hood (as I have just seen in some other posts) but I don't know which fuse to check. I don't want to just start pulling fuses and make a mountain out of what I think is a mole hill.
Help?!
Old May 6, 2013 | 08:57 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum.
The under side of the fuse box cover should have a diagram showing fuse numbers. In the owners manual, there is a section explaining which fuse/relay goes to what.
It could be a bad bulb, bad socket, blown fuse or even the multifunction switch in the steering column.
Old May 7, 2013 | 10:21 AM
dona_moyer's Avatar
dona_moyer
Default $$$ saved!!
Thanks for the help lxman1. I went to the manual and tried to figure out which fuse. I don't understand all of the short-forms used, but I was pretty sure I couldn't find it. So, as I was flipping through the pages, I saw the part about "how to change the rear light bulbs". Those push pin thingys are a pain to get out. Good thing I have a short prybar!!
In the end, and after about an hour of my time, and $12.00 out of my wallet - Problem Solved!
Oh, and the guys at Canadian Tire - where I bought two replacement bulbs - say those lights are run by a relay, and not a fuse... Old dog, new trick. The day is good.
Old May 8, 2013 | 04:27 PM
lxman1's Avatar
lxman1
Site Moderator
They are fused somewhere in the circuit, in case there is a short, to keep the wire from melting and catching fire.
Regardless, I'm glad to hear that you got it fixed! Yeah, those clips are a PITA to get the center pin out of. I recently had to replace a rear bulb on my wife's 09 Caliber.
Thanks for the update too.
