Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
2007 dodge caliber
Old May 22, 2013 | 03:47 PM
Blazer1989's Avatar
Blazer1989
Default 2007 dodge caliber
If anyone can help me I have a 2007 Dodge caliber Drivers low beam headlight went out Replaced the headlights and now there is no headlight Bought a second bulb and put it in and still no low beam Switched the bulb to the other side and it worked But doesn't not come on on the drivers side I have highbeam but no low
Old May 22, 2013 | 04:29 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum
It could be a bad fuse panel of possibly the multi-function switch on the steering column.
Old May 24, 2013 | 02:51 AM
Blazer1989's Avatar
Blazer1989
Would that cause one light to work and one not to work
I don't know my way round the wiring
Old May 25, 2013 | 08:33 PM
lxman1's Avatar
lxman1
Site Moderator
I believe they are on different circuits. Look in the under hood fuse panel and see if there are separate fuses for the left and right headlights. I can't remember off the top of my head. I think they come out of the multi-function switch in the steering column separate as well, so it could have a bad low beam connection.
In the READ FIRST section at the top of the Caliber forum, there is a thread with a link to download a free service manual. It may have the info that you need.
Old May 26, 2013 | 12:03 AM
steak59's Avatar
steak59
I think your problem will be the fuse box. And they r expensive. You could by pass it with by installing a relay to substitute the box tho. But it will take some know how around wiring repair.
Old May 28, 2013 | 07:04 PM
Shelly1973's Avatar
Shelly1973
Had the same thing it was the module in the headlight could not figure a way to bypass it 700$ fix RIDICOULSE
Old Jun 5, 2013 | 03:05 PM
Blazer1989's Avatar
Blazer1989
Does anyone by chance have a link to a wiring diagram for the headlights on a 2007 Dodge caliber
