Dodge Caliber The new sporty Dodge Caliber is a hatchback that replaces the Dodge Neon. The Dodge Caliber is here to stay!
transmission overheating
Old Jul 4, 2013 | 11:02 PM
natenate4s's Avatar
natenate4s
Default transmission overheating
Hello everyone. I have a 2007 dodge caliber. The transmission overheats when I drive on the highway. It's ok at first, but then if I drive over 60 mph for about 30 minutes, it overheats, and loses power. Once it cools down its fine again. It doesn't overheat while I'm driving in town. Any ideas on how to fix it?
Old Jul 5, 2013 | 03:57 PM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum.
Have you had the fluid level checked? You have to have the proper scan tool to properly check it. usually trans shop or dealer will have to check it, it has no dipstick.
Old Jul 5, 2013 | 07:30 PM
natenate4s's Avatar
natenate4s
No I haven't yet. Took it to midas, they said I gotta go to a dealer. Yay
Old Jul 8, 2013 | 04:25 PM
moe7404's Avatar
moe7404
check that the coolant line hasnt been crushed.. some chrysler trans systems have a check valve in the coolan line, that can clog, every one says to remove the check valve. have a GOOD trans shop check that out. and is the engine overheating? time for extra cooler?
Old Jul 9, 2013 | 12:12 AM
master tech's Avatar
master tech
Site Moderator & Tech
Here are some mopar numbers for the dealer, Because they may not be able to find the numbers.
68004297AA - Transmission oil cooler TOC (positioned in front of radiator)
68004296AA - Condenser (positioned in front of Trans oil cooler)
68021178AA - Trans oil line
68021180AA - O-ring for trans oil line
05058578AF - AC unified lines
05058577AC - AC discharge line
